Oil Pressure sending unit install gone bad
Old Mar 29, 2017 | 03:53 PM
neilca's Avatar
neilca
Default Oil Pressure sending unit install gone bad
I am airing my stupidity so maybe no one else will fall into the trap. I changed my oil pressure sending unit and over torqued it. This cracks the upper pan. BTW the total torque on this unit is 10 ft-lbs which is about finger tight. I am now looking at replacing the upper pan to fix my stupidity
Old Mar 29, 2017 | 08:10 PM
bealljk's Avatar
bealljk
Yea...
I laugh because I did the same thing a few years back...in-fact, there's many people who have so dont feel too bad...
on the bright side...if you ever wanted to build the block now would be the time!
Old Mar 29, 2017 | 09:06 PM
terrasmak's Avatar
I have made this mental note many times ,
Old Mar 30, 2017 | 01:15 PM
dcains's Avatar
dcains
Whenever I see a new thread in which someone mentions they're going to replace the sender, I warn that about this issue. If mine ever fails, that will be the one time I'll take my car to a Nissan dealer and put the risk on them. I do recall a thread where someone was able to repair theirs using JB Weld.
Old Mar 30, 2017 | 03:02 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Sorry to hear, and yes, those fittings are quite fragile. Finger tight and checking them for leaks is about the best you can do...
Old Mar 30, 2017 | 10:54 PM
i8acobra's Avatar
i8acobra
This actually applies to any fitting that uses pipe thread. NPT fittings are tapered, not straight like machine thread.
Old Apr 15, 2017 | 05:26 AM
neilca's Avatar
neilca
The upper pan has now been replaced. I had it done professionally and they only charged me $500 to do it. I am going to do my best to ignore the oil pressure gauge on this car because I have no faith in the reading. Goes against my nature but bad data is bad data.
Old Apr 16, 2017 | 09:31 AM
bealljk's Avatar
bealljk
I wouldnt ignore it...if it's reading zero (or close to) check to ensure you have oil!
Old Apr 16, 2017 | 11:55 AM
neilca's Avatar
neilca
It is not zero, it ranges from 20-120 at the same temperature differing RPMs
Old Apr 17, 2017 | 02:57 PM
bealljk's Avatar
bealljk
^ok...nevermind...def just ignore it
