Someone help! I have a few questions that need answers ASAP
Old Jun 3, 2019 | 11:53 PM
MakelR's Avatar
MakelR
Default Someone help! I have a few questions that need answers ASAP
Okay my car makes a weird like a rattling scratchy noise bu when I press the clutch it goes away?
When I accelerate it rattles but goes away once the RPMs get higher? & and I hear that same rattling scratchy noise when I ride in low RPMs it’s starting to get real annoying! I thought it was my clutch or throw out bearing but it won’t I just replaced both.
Old Jun 4, 2019 | 03:09 AM
813_350Z's Avatar
813_350Z
Just because it's new doesn't mean it was done right or isn't faulty.
Old Jun 4, 2019 | 03:17 AM
Heel Til I Die's Avatar
Heel Til I Die
Sounds like typical lightweight flywheel noise.
Old Jun 4, 2019 | 06:30 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
This ^^^ OR just the usual gear clatter from the transmission, particularly notable on the HR engine with JK transmission (supersedes CD009 but is "pretty much" the same transmission.)
But without putting hands on (or ear to) the transmission/clutch, this is merely a guess. Posting a video might help but best to have someone along that knows that can listen to it.
Old Jun 4, 2019 | 08:50 AM
travlee's Avatar
travlee
Master
jeebus
Old Jun 6, 2019 | 06:23 PM
MakelR's Avatar
MakelR
That’s true
Old Jun 6, 2019 | 06:28 PM
MakelR's Avatar
MakelR
I have the DE though , I did a lil more research and the torque converter match my symptoms, so if it is that should I just replace the whole transmission?
Old Jun 6, 2019 | 06:29 PM
MakelR's Avatar
MakelR
Originally Posted by travlee
jeebus
I know, so annoying!
Old Jun 6, 2019 | 06:57 PM
MicVelo's Avatar
Ah, ok, AT means a whole different set if “possibilities”, unfortunately something I can’t address. However, that said, I wouldn’t do anything as drastic as swapping the trans (possibly to find out that isn’t the issue). The “Throwing parts at it” methodology might be fine for cheaper parts like sensors; but a transmission? Uh no.
My only real advice is to Take it to a transmission sho to get an expert opinion.
Old Jun 7, 2019 | 04:27 AM
MakelR's Avatar
MakelR
thanks for the help! Really appreciate it
Mr_pharmD
Tuning
Sep 1, 2006 08:06 PM
Everybodywildou
Nov 1, 2005 11:25 PM
oaktown2000
May 13, 2005 02:45 PM
