Top not working 06 350z roadster
Old Jun 18, 2021 | 03:57 AM
RossG's Avatar
RossG
Default Top not working 06 350z roadster
So before I'm told to search I did. Can't seem to find my exact issue. I'm hoping I can get some help.
when I try to drop the top I push the button but only thing that happens is top releases from trunk. I have no power at the 5th bow motor. I can power the motor and it works well. Not lsure if it's a switch a relay or something else. Any help on this would be great. I bought the car like this prior owner pulled the 5th bow motor thinking that was the issue. I cleaned and tested the motor. It works nice and smooth.
Old Jun 21, 2021 | 11:20 AM
RossG's Avatar
RossG
did I put this in the wrong place? Can no one offer assistance?
Old Jun 22, 2021 | 09:38 AM
jhc's Avatar
jhc
General & Tech Moderator
It's in the correct spot, it's just that the subject has been covered sooo many times.
Start by checking your fuses and confirm that your brake/tail lights come on when the pedal is pressed. Read every related thread, you'll likely find the solution. Gl!
Old Jun 23, 2021 | 01:26 AM
RossG's Avatar
RossG
I have done all that . Problem I have does not seem the same as the posts I find.
Old Jun 23, 2021 | 03:35 PM
Heel Til I Die's Avatar
Heel Til I Die
It sounds like you have a rather obscure problem and a trip to the stealership may be in order.
Old Nov 28, 2021 | 04:42 PM
Dbld's Avatar
Dbld
I'm having the same problem.puchased my car Friday with top down and known not to work.to my surprise the next morning,hit the switch and it went up,till it got to the 5th bow function. Rebuilt my 5th bow motor today and bench tested.didnt change a thing
Old Nov 28, 2021 | 04:46 PM
Dbld's Avatar
Dbld
Jeremy Gherardi
May 30, 2023 04:59 AM
Brandon Salas
Jun 6, 2019 07:50 AM
Adoty949
350Z Roadster
Sep 23, 2017 05:34 AM
brady0323
350Z Roadster
Jun 4, 2013 10:40 PM
krunch
350Z Roadster
Aug 23, 2012 05:09 PM
