brake dust?
Old Mar 18, 2004 | 07:46 PM
maximadave's Avatar
maximadave
Default brake dust?
My Mom just purchased a Roadster and is telling me that the front wheels are collecting alot of brake dust. Is this normal for a Z Roadster?
thanks for the replies...
Old Mar 18, 2004 | 08:05 PM
ragtopz's Avatar
ragtopz
it is normal for the z in general. in one week's time, the front wheels look like doo doo.
only remedy is to wash it very often or change to a low dust pad.
Old Mar 18, 2004 | 09:24 PM
yobri's Avatar
yobri
Default Re: brake dust?
No, we have special front wheels that have automatic gunmetal color conversions.
Yeah, like ragtop said, changing the pads will help a lot.
Old Mar 19, 2004 | 05:20 AM
MrNicholas's Avatar
MrNicholas
Oh my yes. This car produces more dust than any I've ever seen*. So much in fact that I've taken to carrying a rag with me just to wipe the wheels with.
As said before, changing your brake pads to something better will reduce the amount.
* I have a running joke with a friend that's about the cloud of dust I kick up every time I brake
Old Mar 19, 2004 | 12:31 PM
THE ROADSTER's Avatar
THE ROADSTER
Default get hrome rims, it will help
I notice you are in the city of Murrieta, Barney Wheels in Temecula will do the exhange for chrome rims for $700. I got chrome rims on my roadster and love them very much.
Old Mar 19, 2004 | 02:32 PM
mode101's Avatar
mode101
my 04 has tons of brakedust .... 4-5 days after a wash my rims are black
and another thing.. my brakes squeek too !! freekin annoying
Old Mar 19, 2004 | 05:24 PM
maximadave's Avatar
maximadave
Default Re: get hrome rims, it will help
thanks for the hookup on the wheel exchange. I actually work at Quality Nissan in Temecula and can probably get it for less than $700.00. I'll look into it.
She wants a rear wing now. any suggestions?
Old Mar 19, 2004 | 08:29 PM
THE ROADSTER
Default I thought about it , but my conclusion is no
I thought about wing on my roadster so it can be done at the same time with my body kit but my conclusion is no.
Mabeya small wing is ok.
Old Mar 22, 2004 | 05:48 AM
ephilyawjr's Avatar
ephilyawjr
Default For a wing
You might consider just going with the OEM wing. If the truck is open and you put the top down the Cover and trunk will hit each other. The OEM is about the smallest one around.
Old Mar 22, 2004 | 11:42 AM
integra47's Avatar
integra47
Default try crystal guard on wheels
Mine gets loads of break dust too, but recently when i applied crystal guard to the roadster, I used some on the wheels also...
Results are outstanding - I haven't had to wipe my wheels again, and they stay clean!
good luck!
John
2004 DB roadster - 2wks old, and I'm still in love...
Old Mar 22, 2004 | 03:15 PM
DeZigner's Avatar
DeZigner
Default Re: try crystal guard on wheels
good luck!
John
I did the same with Zaino with good results.
Old Mar 28, 2004 | 07:25 PM
topdown-z's Avatar
topdown-z
Angry Brake Dust
GreenStuff or Hawk
ONLY
WAY
GO
Old Mar 31, 2004 | 11:47 AM
ciramjo's Avatar
ciramjo
I had the same complaint. Advice was to change pads to either Greenstuff or Hawk HPS. I went for the Hawk pads b/c they were consderably cheaper. The pads just arrived today. I hope to install them over the weekend
Old Mar 31, 2004 | 03:27 PM
integra47's Avatar
integra47
ciramjo,
I would like to hear how you like the new pads. Also how difficult theywere to install and how you would rate their performance compared to stock.
thanks
Old Apr 1, 2004 | 06:16 PM
KingofScion's Avatar
KingofScion
Yes, please change give me a review of the brake pad change.
Old Apr 3, 2004 | 07:09 PM
topdown-z's Avatar
topdown-z
Talking BRAKE DUST
Just my 2 cents.........
I replaced my pads with GreenStuff about 3,500 miles ago because of the brake dust issue. I simply got tired of cleaning my wheels every day.
They were very easy to change, taking about 45 minutes total.
Now...........no dust. Just a very little after 750-1000 miles. All I have to do now is just spray a little water on my wheels and wipe off the little dust that is there. I am now a Happy Camper.
Old Apr 5, 2004 | 12:27 PM
ciramjo's Avatar
ciramjo
Well, I installed my Hawk HPS pads on Friday. It was very easy. After removing the wheels, you remove only bolt from the caliper (the lower one furthest from the brake line), rotate the caliper out of the way and install the new pads using the shims from the old pads. I also used some anti-squeal compound from 3M, but I'm not sure that's necessary. Push back the master cylinder with a c-clamp, rotate the caliper back, install the caliper bolt and wheel and you're done. Brakes work fine with no squeal. It's only been a couple of days, but so far no sign of dust. The stopping performance is supposed to better than the OEM pads, but I have no way to evaluate that. The car still stops fine just as it always did. I'll let you know more on the dust situation in a week or so. The pads cost me $60 plus $4 shipping. And yes, my wife thinks I'm crazy!
Old Apr 6, 2004 | 06:39 AM
integra47's Avatar
integra47
Thanks, Ciramjo
and thanks for the details of the mechancal proceedure. I will be interested to hear about the dust issue when you get a few more miles on the new pads.
Thanks again
John
Old Apr 8, 2004 | 06:05 AM
ciramjo's Avatar
ciramjo
I'ts been about a week and I have about 120 miles on my new Hawk HPS front brake pads now and I have no real complaints. The amount of brake dust produced is dramatically reduced from what it was with with the oem pads, but there is a layer of dust on the rims - about the same amount as on the rear wheels that still have the oem pads, and about as much as I would expect from any car. I am a little disappointed since I was expecting even less dust from what I've read, but I'm not unhappy. Maybe when they wear out I'll try the Greenstuff pads to see how they compare.
John
Old Apr 8, 2004 | 11:47 AM
integra47's Avatar
integra47
Thanks, Ciramjo:
Sorry to hear you are disappointed with the new pads, but I appreciate the info. At the rate mine are wearing, it won't be long until I replace them... Based on your experience, I try the 'greenstuff' and see if they perform better. As for the dust, since I started putting crystal guard on the wheels, it hasn't been to much of a problem...you might try yourself.
regards,
John
