Alarm On The Roadster ?
Old Apr 23, 2004 | 09:29 AM
Loic's Avatar
Loic
Question Alarm On The Roadster ?
That might be a stupid question but is there a built in alarm on the roadster other than the chip in the key ?
Old Apr 23, 2004 | 04:43 PM
AndyB's Avatar
AndyB
Default Yup,
There is an alarm on my Touring Roadster. I am guessing it is on the other roadster model to.
It is pretty smart. If you lock the car with the remote, then reach inside and unlock the door and open it the alarm goes off.
Old Apr 23, 2004 | 04:45 PM
Loic's Avatar
Loic
Default Re: Yup,
Really ? I have to try that, that's cool....
Old May 1, 2004 | 01:04 PM
FLZ's Avatar
FLZ
I keep setting mine off whenever I put my damn key fob in pocket. Scares the crap out of me every time:-)
Old May 5, 2004 | 11:10 AM
Loic's Avatar
Loic
Default Re: Yup,
I have a touring raodster too, I tried what you described and nothing happen.....
I locked the door with the remote, let the window open, reached inside and unlocked the door but the alarm did not go off !!!
Do you have to wait sometime for the alarm to activate ?
What's going on......
Old May 5, 2004 | 05:53 PM
LemanZ's Avatar
LemanZ
i hv a touring roadster too, I m sure the alarm is an optional from the dealer unless u buy the demo model or second hand (some dude may order that option). But I fit my with the pager alarm with microrave sencer, so i can park my Zed with the top open. anyone put their hand into the car will set the alarm go off!!! The alarm come with the remote start function which require to cut the chip from ur key. so I didn't do that.
Old May 6, 2004 | 04:23 AM
AndyB's Avatar
AndyB
Default unlock
I unlocked it by moving the lever by the door handle.
Maybe if you unlock it with the button it disables the alarm.
If I leave the car top down (rare) I at least leave the windows up. That way nobody can reach the button, just the lever.
But mostly I am too paranoid and put the top up and lock it if I will be out of sight.
Old May 6, 2004 | 06:33 AM
flukechance's Avatar
flukechance
Default Alarm Activation Delay
I went to the dealer with the same question. I was about to install an alarm system because I thought I didn't have one.
They proved to me that once you set the alarm there is a certain time delay, how long I'm not sure, and then if you reach in and unlock and open the door the alarm will go off.
I don't think that it has any shock sensors tho.
Old May 8, 2004 | 07:58 PM
Loic's Avatar
Loic
Default Re: unlock
I closed the door using the remote, the car was top down windows down, and I opened one of the door using the lever but nothing happenned.....
Is there a special procedure to enable the alarm....my roadster is from November 04...
Old May 16, 2004 | 09:54 PM
Paul_BB_Guy's Avatar
Paul_BB_Guy
You definitely have to wait a good bit before the alarm gets armed. I was trying this today. I locked the doors with the FOB, reached in and manually unlocked and opened the door... Nothing.
Later on, I locked the car and went inside for a bit. I came out and tried again and sure enough when I reached in, unlocked the door and opened the door the alarm SCREAMED!
I'd still like to get a two-way so I can get warning when the car is approached.
Old May 17, 2004 | 01:43 AM
shopdog's Avatar
shopdog
The alarm is armed when the LED goes from solidly lit
to blinking, about 30 seconds after you arm it.
Old May 17, 2004 | 02:58 PM
Loic's Avatar
Loic
Not on my roadster at least....I've be waiting few minutes and still the alarm did not go off
Old May 17, 2004 | 10:26 PM
shopdog's Avatar
shopdog
What can I say? Mine works the way I described, and that's
the way the owner's manual says it is supposed to work too.
BTW, mine is a Daytona Blue Touring roadster, white leather,
with the 18 inch wheel option and the NAV option. I took delivery
April 24th. I have 780 miles on it now, still babying it until the
official 1200 mile break in period is complete.
Old May 18, 2004 | 09:20 PM
Loic's Avatar
Loic
Try again today with the roof up and it works exactly as described in the manual....I guess I must have screw up somewhere...I still have to try with the roof down....
Old May 19, 2004 | 05:46 AM
boldenmd's Avatar
boldenmd
Mine goes off whether the roof is up or down. That doesn't seem to matter. You do have to wait like a minute or so before this happens.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
jlb
Oct 15, 2017 05:10 AM
kyin
Oct 15, 2015 05:54 AM
416blueZ
Sep 25, 2015 10:00 AM
