Tapping into Antennae for XM Wireless
Old Jun 5, 2004 | 11:19 AM
je350z's Avatar
je350z
Default Tapping into Antennae for XM Wireless
Anyone taken the radio out fo the dash? I want to know what the first steps are to removing it...I need to run a wire to the antennae input and don't want to break anything while doing it.
Thanks,
Jeff
Old Jun 25, 2004 | 10:41 AM
sq40's Avatar
sq40
Remove the Trim Ring from the Shifter.
Pull that Pannel (With Climate controls and All) Up and Out.
Remove the two Screws from the Nav Cubbie Hole.
Remove the Two Screws from beneith the radio.
Lift Up and Off the center Dash Peice, Disconnect the Wire to the Guages.
Remove the 4 Screws that hold down the radio inside the dash.
Remove.
The Antena hides easily underneath the rear of the Tonnau cover on the body beam and gets great signal.
Good Luck.
Tracy/>
Super Black '04 Roadster.
Old Jun 27, 2004 | 04:50 AM
Darthvol's Avatar
Darthvol
Remove.
Good Luck.
Tracy/>
Thanks, Tracy; I needed same info. Also, which system did you install? SKYFi? Roady? And where/how did you mount it? If poss., I would like to try the cubby where the navi would go if I had one.
Old Jun 27, 2004 | 07:32 AM
sq40's Avatar
sq40
I Installed the SkyFi Unit. I had to remove the circuit board and Cut the Harness.
To be honest, It is really worth just getting the Roady and putting it in there.
Old Jun 28, 2004 | 06:26 AM
jteuscher's Avatar
jteuscher
Default XM Antenna in the Roadster
Could you describe with more detail where you mounted the XM antenna in the roadster? Also, how did you route the wire?
I've got mine on the left corner of the dash, and it works fine 99% of the time. Looking for a better option.
Thanks a lot,
Jim in Virginia
Old Jun 28, 2004 | 12:10 PM
sq40's Avatar
sq40
Ill take a picture and Post it up, In the mean time,
The Antenae is mounted on the Beam between the trunk and Tonnau cover. Under the rear ledge of the cover. There is about 2 inches of clearance under there and the cover does not touch it.
It then goes under the fabric inside the Convertible roof boot, and down through next to the glove box and through the trim molding under the doors.
Old Jun 30, 2004 | 04:43 PM
jteuscher's Avatar
jteuscher
Thanks a lot for the info. I'll check it out. Look forward to the photos.
Thanks again.
Jim
Old Jun 30, 2004 | 08:06 PM
hrohawg's Avatar
hrohawg
I just had a XM Commander installed today in the rear of my 'nav hole'. Antenna is mounted on the little flat spot between the left and right defroster vents. Even though the manual says specifically not to mount the antenna inside the cabin, mine seems to get a good signal in general driving today.
If the wife hadn't hidden the digital camera, I'd post a pic but the install looks really nice in there and there wasn't much modification made to the NAV hole housing... I can take it out if needed in 10 years when I'm ready to sell the car.
$210 installed. Not bad.
Note: The shop that installed it also carried the Delphi SkyFi but swore off the Roady. Seems Delphi is having some problem with the Roady in import cars. The SkyFi requires alot more cutting of the NAV box so if you ever wanted to remove the system, you'd have to replace the entire box.
Old Jul 2, 2004 | 06:51 AM
jteuscher's Avatar
jteuscher
Thanks so much for the reply. I've got a Roady and it's been working fine. I'll keep an eye it.
Thanks again,
Jim in Virginia
reno56
Interior
17
Nov 20, 2015 05:21 PM
bcoffee20
Nov 19, 2015 06:39 PM
cashmoney03
Sep 27, 2015 05:24 PM
3vilbunny
Sep 13, 2015 12:31 PM
