Cleaning & Protecting Top
Old Jul 6, 2004 | 12:15 PM
Zcool's Avatar
Zcool
Default Cleaning & Protecting Top
There has been considerable discussion about the composition of the roadster top. Vinyl vs cloth. I think the final agreement is that the material is primarily cloth but may have a vinyl underlayer.
I have been trying to find a product to clean and protect the top that is specific to this type of material but all the auto supply stores I have been to said they don't know of anything. What have you found that is a good cleaner and protectant? One product does both or do you need two different prodcuts?
Old Jul 6, 2004 | 01:41 PM
ZRoadsterClub's Avatar
ZRoadsterClub
What I've heard:
- RaggTopp line from Wolfsteins Pro-Series www.wolfsteins.com.
- Other care and cleaning at www.haartz.com.
- Don't forget the manual says use mild soap for cleaning.
Old Jul 6, 2004 | 01:46 PM
SpyderGurl's Avatar
SpyderGurl
links don't work
Old Jul 6, 2004 | 01:57 PM
elyliu's Avatar
elyliu
I use vinylex on mine... found it at pep boys...
there's a lot of people that use 303 too
Old Jul 7, 2004 | 10:44 AM
sluggoZ's Avatar
sluggoZ
A friend of mine owns a Auto detail shop. He suggested & sold me a gallon jug of Finale Products...."Leather Treatment"...for leather and vinyl. I have a SuperBlack/Black Roadster. What a beautiful rich looking appearance it gave to the top. No side effects like gathering dust & etc. The label says that it leaves leather soft - restores oil & protects - non-staining. So far...I'm very happy with the results ps.. I also use it for my Hot Tub cover!
Old Jul 7, 2004 | 10:02 PM
elyliu's Avatar
elyliu
hmmm where can you get this Finale Product?....
and leaves the top looking dark?....do you have pics, sluggoZ?
Old Jul 22, 2004 | 12:43 PM
sluggoZ's Avatar
sluggoZ
On the gallon label...its made in Perrysburg, Ohio phone number......1-419-874-2662...Personally I have not tried to contact them by phone. I just applied another coat to day and I use a applicator to apply. It leaves a nice rich looking effect to the top. I do not have pics....still learning the pic process. Good Luck!
Old Jul 27, 2004 | 11:02 AM
maxpowers's Avatar
maxpowers
Just had my top replaced. I had it outsourced to a place that specializes in convertible tops, the busines has been around for 75 years doing convertibles so I figured he should do a good job.
I asked him what the top was made out of. He said it was made out of "stayfast" which is a synthetic material made by Haartz. They purchase it sometimes when they custom make soft tops. He said its definatley not Canvas but not really Vinyl either. He said to use vinyl cleaner or mild soap.
Waterproofing is not neccessary. The top doesn't have to bead water, the synthetic material is water proof. This is opposed to canvas which should bead because its not waterproof.
Just though I would pass along what he told me.
Old Jul 27, 2004 | 03:49 PM
sluggoZ's Avatar
sluggoZ
maxpowers......Thanks.....Makes a lot of common sense to me!
Old Jul 29, 2004 | 06:11 AM
goldndwgz's Avatar
goldndwgz
use Raggtopp
http://www.topoftheline.com/ragcleanprot.html
http://www.autopia-carcare.com/exter...-top-care.html
Old Jul 30, 2004 | 09:08 PM
SeanG's Avatar
SeanG
The top may be waterproof, but using a protectant like Ragtopp is always a good idea. It has UV blockers in it which will help keep your top from fading.
Old Jul 31, 2004 | 12:38 PM
Marksf1's Avatar
Marksf1
I went to www.haartz.com and it listed "stayfast" as a cloth product. I wonder why your the vendor said to use vinyl cleaner if indeed "stayfast" is a cloth product.
Old Aug 3, 2004 | 05:45 AM
maxpowers's Avatar
maxpowers
From Haartz:
"A three ply composite made of 100% acrylic square weave outer fabric, a butyl rubber inner layer and a 100% cotton drill lining fabric."
A quick search on the net revealed the acrylic is made from plastic. The instructions for the Ragtopp protectant for vinyl tops describes it can by used on vinyl, rubber, plastics etc.
This is probably where my installer was coming from.
Old Aug 16, 2004 | 04:49 PM
Zcool's Avatar
Zcool
I ordered Raggtopp from the first above link and I concur that this is an excellent product. The cleaner works well and the protectant sheds water like off a duck's back. I've attached a pic to show how the water beads up after applying the protectant.
Old Aug 16, 2004 | 06:26 PM
Marksf1's Avatar
Marksf1
Look good - WHich one did you get vinyl or cloth? I am ready to order once I find out.
Old Aug 16, 2004 | 07:20 PM
Zcool's Avatar
Zcool
I got the cleaner and protectant kit for fabric tops.
Old Aug 16, 2004 | 09:23 PM
SpyderGurl's Avatar
SpyderGurl
Zcool . . . what did u use to apply those 2 products
Old Aug 17, 2004 | 04:52 AM
DeZigner's Avatar
DeZigner
I also have used the cleaner and protectant kit for fabric tops. After several months I am still happy with the results.
Old Aug 17, 2004 | 08:09 AM
Zcool's Avatar
Zcool
I scrubbed the cleaner on with a soft bristtle scrub brush, rinsed it off and once the top was completely dry sprayed on the protectant. It comes in a spray can. You have to be careful not spray the protectant on painted surfaces or windows. I used an old bed sheet to protect these surfaces by opening the top and putting the sheet in place and then closing the top but not quite all the way so that it latches.
Old Aug 19, 2004 | 06:45 PM
netman_one's Avatar
netman_one
Default Re: Cleaning & Protecting Top
http://www.protectiveproductscorp.com/formula2.htm
Wash my top with water only when I wash my car (spring water).
Use Formula 2 on ragtop, dash, center console. - cleans/protects.
issyz
Jul 2, 2017 03:04 PM
Stevo Z
Oct 3, 2015 09:14 PM
nanotech
Oct 2, 2015 05:02 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
