5V pre-outs
Old Dec 13, 2004 | 07:27 AM
dannichols's Avatar
dannichols
Default 5V pre-outs
Simple question. There are a few heaad units out there with 5V pre-outs. However, I am finding that the majority of mid-level Amps handle somewhat less (like 4V or less). Will a head-unit/amp combination missmatch still work, compensate, or cause meltdown? Example Kenwood Excelon --> Alpine V12 amp
Old Dec 13, 2004 | 09:12 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
It will work just fine. If, which is wont, there is a problem there is a 20 dollar fix.
Old Dec 13, 2004 | 09:17 AM
dannichols's Avatar
dannichols
muchas gracias. I called Alpine and they told me the same. Suggested I may need to increase the gainon the amp. My system sounds distorted at low volumes..maybe it's my speakers.... ;-(
Old Dec 13, 2004 | 09:50 AM
parboy's Avatar
parboy
The higher the output voltage of the head unit means you should be able to turn the gains down on the amp and get similar volume to a lower output HU with amp gains up. In theory this means there is less chance of noise interference due to having the amp gains set too high. The eclipse HU in my supra has 8v outputs. Eclipse also has HU's with 16v balanced outputs that are supposedly really nice, though I have not heard that particular head unit.
Old Dec 13, 2004 | 01:18 PM
Nazar's Avatar
Nazar
Without getting into the details of the subjact, You also have to think about the impedence of the Outputs. Like the Eclipse units versus Alpine Units. Eclispe Claims 8Volt at a certin Impedence (Ohms) And Alpine may have a lower Voltage but different Impedence.
Just my .02 cents.
Old Dec 13, 2004 | 02:25 PM
rplink's Avatar
rplink
The Eclipse deck parboy mentions is the CD8061. 16V balanced line outs, copper chassis, etc. Great deck.
Here's a link to an excellent reference site that describes lots of mobile audio situations:
http://www.bcae1.com/gaincon2.htm
Good luck.
Old Dec 13, 2004 | 02:28 PM
rplink's Avatar
rplink
There are other methods if you don't have access to O'scopes and recorded sine waves.
Let me know if you want a description for other methods.
Old Dec 13, 2004 | 02:42 PM
dannichols's Avatar
dannichols
Thanks RPLINK.
Limited350z
Mar 18, 2008 07:14 AM
rplink
Audio Builds
86
Jun 20, 2006 12:51 PM
cehome
May 22, 2005 02:06 PM
cehome
Feb 4, 2005 10:43 AM
