$200 just to bypass BOSE?
I just went into a stereo shop today to see about getting a new headunit. On top of the headunit's price and the $50 dash kit/harness, I was also quoted to be charged $150 to bypass factory amps and $50 for a Bose adapter. I told them I wanted to use my factory speakers for now but was also told that the sub would not work and the sound from the navigation wouldn't either.
Is this something I could easily do on my own? What's a BOSE adapter? Can I just pull out my bose headunit and swap it just like any other headunit in a regular car except that I'll lose navigation voice? Or is this $200 labor charge because you can't just simply swap out a headunit otherwise the Bose speakers will stop working.
Thanks!
Thanks!
When I used to have a camaro with a bose system in it, the stereo shop tried to tell me the same thing. I never ended up replacing the headunit though so I can't tell you if it's legit or not, but I have heard the same thing.
Well, I called up Crutchfield and they told me that their wiring harness adapts straight into the BOSE setup. The only thing I'll lose is the voice on the nav -- which is OK!
I guess the shop had never dealt with a 350Z with Bose & Nav and bumped up the labor cost anticipating a more difficult install. But I'm gonna just do it on my own with Crutchfield's harness & install kit. It'll all work with the factory amp, sub, and speakers.
I replaced my Bose and didnt use any adapter or anything and my stock speakers still worked fine. Cant tell you anything about the nav voice because I didnt have the nav option in my Z though, I have aftermarket nav.
Or, they could be B.Sing you and just trying to take your money!
Frys tried to charge my dad 800 bucks to install a Clarion CD Player into my moms old Mercedes, as he SWORE it had a BOSE in it.
Mercedes use Becker systems. I did the install myself for free. No Bose mess, no super fancy installs, though it does have an amp, and I did have to runa long wire for the antenna, bu 800 bucks!?
m_0g
Jun 3, 2021 10:05 AM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
