Switching inputs for an Amp
Old Jan 4, 2005 | 02:42 PM
eddiesbu's Avatar
eddiesbu
Default Switching inputs for an Amp
I was wondering if it was pssible to have to inputs into an amp?? like say one from an OEM HU( speaker wire input) and say from another HU which connects through RCAs How would I be able to do that??
Thanks
Old Jan 4, 2005 | 09:08 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
2 y adaptors would work justttttt fine
Old Jan 5, 2005 | 01:06 PM
eddiesbu's Avatar
eddiesbu
Th alpine 4 ch amp has wire input and rca input, if I put both in would it work?
thanks
Old Jan 5, 2005 | 02:20 PM
dannichols's Avatar
dannichols
The amps I have had specifically stated one or the other, not both simultaneously.. But I think the advice to use Y-splitters might work..of course you would need to provide RCA inputs from both sources or use an LOC.
Old Jan 6, 2005 | 02:46 PM
eddiesbu's Avatar
eddiesbu
what would be the best way to convert the stock head unit lines to RCA lines?
Old Jan 6, 2005 | 03:08 PM
dannichols's Avatar
dannichols
I tried two methods in the past.. Line output converters (LOC) and high-inputs on the amp. Neither one produced the sound quality I needed so I ended up with a new head unit. But anyway-
LOC - range from cheapies by Tsunami or at pep Boys to expensive such as Audiolink. **Basic wiring hookup is speaker output from head unit connects to input of LOC. Gain controls are usually included on the LOC and then RCA out to amp. Single or dual LOCs can also serve as quad input to amp with Y RCA adapters if you are not concerned with front/rear fading.
In my trials I got the best response turning down the level on the LOC and turning up the gain on the amp. Also I can say I was more successful running hi to lo converters for Subs (using the lo-pass filter on the amp) than trying to use them for mid-range.
Old Jan 7, 2005 | 02:21 AM
eddiesbu's Avatar
eddiesbu
ok thanks for your help
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
