Switching out stock bose 6disc touring model
Old Jan 20, 2005 | 03:04 PM
Dissolved's Avatar
Dissolved
Default Switching out stock bose 6disc touring model
I want to just change my head unit. To do this, I need to bypass the stock bose amp right??? Is this hard to do?
I would need to find a powerful head unit to power my speakers since I wont be able to use the Bose amp anymore....right?
btw: I already have an infiniti self powered basslink
Old Jan 20, 2005 | 05:12 PM
Shahrum's Avatar
Shahrum
Nope, you don't have to bypass anything. I ordered a Sony headunit off Crutchfield.com to replace my premium Bose 6 cd changer headunit and used the wiring harnesses they supply and all of my Bose speakers are still amplified with the factory amps and my subwoofer still works great as well.
Old Jan 20, 2005 | 05:16 PM
Dissolved's Avatar
Dissolved
good to know. How hard was the install? I want to get an mp3 headunit. Will it just be as clean of an installation as you described?
Also, I'm going to have an infiniti basslink connected. WIll that cause a problem?
Old Jan 21, 2005 | 06:03 AM
Shahrum's Avatar
Shahrum
Haha, well, if this looks clean to you, then yes, it's clean lol!!
But no, on a more serious note, it's quite easy to get it installed, if you don't have GPS. If you have GPS, then you have a bit more to remove before you can get the stock headunit out. But it was very straightforward. I'm sure the basslink would be perfectly fine and even easier to hook up to an aftermarket HU than it would be to the stock bose. Take a look at the headunit I got. Not a bad price ($250) from Crutchfield.com and they'll send you (for free) not only the double-din cash fit (that gives you the bottom pocket for storage as well) and also the wiring harness. Not a bad deal. But anyways, the headunit I got looks quite well and compliments the brushed aluminum finish of the 350Z interior. Might be worth taking a look.
Old Jan 22, 2005 | 07:38 PM
Dissolved's Avatar
Dissolved
Hey thanks man. Which headunit did you get? Can it play MP3s? Does it sound better than the stock head unit? So its pretty easy to isntall and it comes with everything I need. Do you have a link? Pretty please? I can use the stock bose amp with this head unit?
Thanks!!
dissolved
ps: I dont have nav.
Old Jan 22, 2005 | 07:43 PM
Dissolved's Avatar
Dissolved
damn, the unit is out of stock. Do you know of any other packages Crutchfield sells for the Z that will give you all the necessary stuff (double din, harness etc).
thanks
Old Jan 22, 2005 | 11:08 PM
Shahrum's Avatar
Shahrum
Hey there,
Sorry for not replying sooner.
Wow, they must have discontinued it soon after I got it, I literally just got it about 2 weeks ago. http://www.crutchfield.com/S-GNvUe8r...ny%20CDXF7705X
Anything you order from Crutchfield.com will include the wiring harness, double din dash kit, instructions, etc. for free -- you just have to specify that it's for a 2003 Nissan 350Z w/ Bose, etc. They'll ask you all of that when ordering online and by phone.
Here's the next model up from the one I got, has red LEDs instead of blue, but here it is:
http://www.crutchfield.com/S-GNvUe8r...y+mp3+headunit
Surprisingly, I thought it sounds better than the stock headunit, most likely because of the 7 band equilizer built into Sony's headunit. I run on 'rock' mode and I listen to mostly alternative/pop/punk/techno/rock. And yes, this headunit/install kit works with all stock speakers, amps, and subs. And everything functions the same, if not better, than before.
Old Jan 23, 2005 | 06:07 AM
Dissolved's Avatar
Dissolved
you are the man. I am ordering it
Old Jan 23, 2005 | 06:15 AM
Dissolved's Avatar
Dissolved
I ordered it. So everything will fit right? (sorry I need reassurance )
Cant wait for it to come. You said the link you provided is a step up above yours?? This has digital signal processing right?
thanks!
Old Jan 23, 2005 | 08:13 AM
Shahrum's Avatar
Shahrum
Yes, it's one model up, I'd assume... it looks practically the same except it is $279 instead of $249.
Old Jan 23, 2005 | 09:03 AM
Dissolved's Avatar
Dissolved
u da man
Old Jan 24, 2005 | 03:27 PM
tight350z's Avatar
tight350z
so if i replace my HU w/the kenwood kvt715dvd i wont have to bypass anything.. it should work right...besides the bose sub? i didnt order mine from crutchfield and i planed on gettin a walmart nissan connector.. think my odds of it workin right are good?!
Old Jan 24, 2005 | 03:39 PM
Dissolved's Avatar
Dissolved
Not sure. This is why i went with crutchfield. Easy match and they give you tech support.
Old Jan 24, 2005 | 04:01 PM
Steve_TexasZ's Avatar
Steve_TexasZ
Be careful matching up your new head unit with the bose system. You should really get a line output converter. The best one for the bose system is the Audiolink PowerDriver PD4. It will successfully do what your planning.
Old Jan 25, 2005 | 04:09 AM
Shahrum's Avatar
Shahrum
The subwoofer and amplifiers for the speakers and sub still work by replacing the factory bose headunit. As long as your sure to follow the Crutchfield instructions on powering the amp (using the wiring harness provided), you will still have a completely functional factory Bose subwoofer and amplified speakers -- no line output converter's necessary.
Old Jan 25, 2005 | 04:54 AM
Dissolved's Avatar
Dissolved
^^ this guy knows his $hit, I'd believe him.
Thanks again Shahnum.
Old Jan 25, 2005 | 05:56 AM
tight350z's Avatar
tight350z
he is correct .. i even talked w/crutchfield about it.. no LOC is needed.. dont listen to any of these other people sayin it is.. my kenwood kvt715dvd will be here today.. i plan on hookin it up i will post some pics later on..
Old Jan 25, 2005 | 09:08 AM
Shahrum's Avatar
Shahrum
Haha, thanks, I love how I've randomly turned into a headunit swapping guru heh. I should get some money out of Crutchfield for these referrals
Oh, btw, they have people there 24/7 live on the phone to help you out. I was up at midnight installing it, and there was someone on the phone to help!
Old Jan 25, 2005 | 05:48 PM
Dissolved's Avatar
Dissolved
Hey man, I got my head unit in today. I noticed the instructions were very thorough. THey covered speaker wiring and such.
I only need to be concerned with the head unit swap right? I shouldnt have to worry about speaker wires and all that nonsense right? The other pages are just there for reference?
thanks!
Old Jan 26, 2005 | 04:42 AM
Shahrum's Avatar
Shahrum
Just wanted to post my response here...
No, ignore the other pages. Crutchfield includes install instructions for the speakers/subwoofer/amp/etc as well as how to install the headunit with all of their products specific to your vehicle. Simply follow the headunit process.
BTW -- Dissolved, would you mind shrinking your sig quite a bit?! It's huge!! Haha! Thanks :-p
