Bose Stereo Problems on Touring Z - Need Suggestions/Comments
Old Jan 21, 2005 | 08:06 AM
dmbmike41's Avatar
dmbmike41
Default Bose Stereo Problems on Touring Z - Need Suggestions/Comments
Hi,
I have a 2004 Touring Z, 13,200 miles.
I play the stereo all the time and periodically, for no apparent reason, the left speakers (left front on the door and the rear head speaker above the sub) seems to cut out, not completely, but their volume and clarity is DRAMATICALLY reduced. Then it will come back... sometimes this problem will last for minutes, then resolve itself for days before coming back. It sounds like a loose connection.
The right side never has problems. I use the fader and balance and notice that it's pretty much the entire left side of speakers (minus the sub) going out. I havent' leaned in and checked that tiny tweeter at about wheel level, but when the left goes out, it gets really really quiet. Sometimes you can hear a crackling sound, but it's not the same type of sound you hear when the speaker is blown in my opinion. Because when the speakers work properly, as they often all do, the stereo sounds very good.
I know some people have complained about the Bose stereo clarity, etc., but I want to get this fixed, and under warranty, and with minimal invasion into the car (ie ripping off panels, etc. to see what the problem is). If it's a loose connection, can I access the point of contact easily? I don't really repair my car a lot here. I'd just like some suggestions or pieces of advice for moving forward here. With such a new car, having the stereo work perfectly 75% + of the time is not acceptable as having it work 100% of the time.
Thanks!.
Old Jan 21, 2005 | 08:16 AM
omarv6's Avatar
omarv6
Oh my good i have the same exact problem ...but now its all the time so low with some kind of cracking and ratteling noise ...i dont know what to do !!! i cant go back to the delar cuse i instaled a bass box with a bilt in amp !!!
i hope some one can help here !
Old Jan 21, 2005 | 09:05 AM
Built2shredZ's Avatar
Built2shredZ
Sounds like a loose connection, pop the door panel off and make sure the connections are tight..
Old Jan 21, 2005 | 09:16 AM
NoahzBurnt's Avatar
NoahzBurnt
When I brake hard the left tweeter goes out.
Nissan told me that it's a problem with the H/U(internally) and they will swap....hope this helps
Old Jan 21, 2005 | 09:29 AM
dmbmike41's Avatar
dmbmike41
Default hmmm
What is the H/U?
Old Jan 21, 2005 | 09:35 AM
NoahzBurnt's Avatar
NoahzBurnt
Head Unit
Old Jan 21, 2005 | 09:48 AM
JonsilvZ's Avatar
JonsilvZ
I thought they fixed the Bose problems on the 04s. They just replaced my amp awhile back. Sounds good now. I also removed the auto up and down volume feature.
Old Jan 21, 2005 | 09:55 AM
dmbmike41's Avatar
dmbmike41
Default hmm
Did you call Nissan Consumer Affairs and have a head unit preordered and sent to your dealership for prompt replacement? I just want this taken care of ASAP. Thanks.
Old Jan 21, 2005 | 10:11 AM
Mantis3024's Avatar
Mantis3024
I have an 04 touring. Can't say Ive had that problem but whenever I start my car and the engine is cold, theres this really annoying loud crackling/static noise busting out of all the speakers for about 10 seconds.
Old Jan 21, 2005 | 10:20 AM
dmbmike41's Avatar
dmbmike41
Default hmmm
I bought my 04 Touring July 1, 04. I never noticed the problem until it started I think about 3 weeks or so ago, it's been VERY cold out and I drive my car everyday.
Old Jan 21, 2005 | 01:39 PM
Tekwon-V's Avatar
Tekwon-V
i have the same problem. but it went away for the time being.
as long as it's working "properly" i am ok with it. besides, when you take it into the dealership, it has to be malfunctioning
maybe i will take it in before warranty expires. good thing i am not into audio system.... just another money pit.
Old Jan 21, 2005 | 02:35 PM
NoahzBurnt's Avatar
NoahzBurnt
Call NNA a few times and complain.....then take it to the dealer and VIOLA...new radio!
Old Jan 21, 2005 | 07:21 PM
Mantis3024's Avatar
Mantis3024
I took my Z to the local dealership earlier today, they looked at it, and ordered a new head unit. It seems thats its less of a hassle to replace the whole unit rather than spending the time and finding the cause of the problem.
Old Jan 21, 2005 | 10:08 PM
barthelb's Avatar
barthelb
Master
Default Re: Bose Stereo Problems on Touring Z - Need Suggestions/Comments
[QUOTE]Originally posted by dmbmike41
[B]Hi,
Holy Crap I have the same exact problem. I balance it so I can hear the left but its all distorted and low. Damn Its gotta be some kind of defect. Everyone laughs at my bose cuz it blows. Gotta get it fixed after its out of the shop
Old Jan 21, 2005 | 10:53 PM
dmbmike41's Avatar
dmbmike41
Default hmm
Mantis that's great... I would hope and expect those kinds of results... I fear what others have mentioned, effectively not being able to reproducce an inconsistent problem with the stereo...it's on and off but hopefully we can get it fixed.
Old Jan 21, 2005 | 11:07 PM
jeffie7's Avatar
jeffie7
Did somoene say bose?
Old Jan 23, 2005 | 07:45 AM
omarv6's Avatar
omarv6
**** i instaled a Subwofer to my stock bose ......now if i go to the dealar thy will not fix it under waranty cuse thy would say i hacked the system !
Old Jan 24, 2005 | 10:34 AM
xtream146's Avatar
xtream146
You know I have the same problem, but it only happends in CD mode and when I am going fast around corners (Left). Weird that it does not happen when I turn right? Just the left side, what happened, Nissan could not put a little more money in getting this right. We paid a good amount for the car and this happens. Well I went to the dealer and they ordered me a new radio and I just got it replaced and everything seems to be working good so far?
Old May 8, 2005 | 02:45 PM
dmbmike41's Avatar
dmbmike41
Default hmm
Well about a month ago I had the head unit replaced under warranty and the same problem is occurring. I think moreso now the cutting out happens on bumps and tight turns.
What should I do next aside from calling consumer affairs? Anyone have comments?
Old May 8, 2005 | 03:32 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
I'd check the cables at the external amplifier under the starboard side aft foam near the spare tire. At least those connections are easy enough to get to. If that wasn't the problem I'd break into the headend and check connections there.
