Help PG amp is cutting off at higher volumes
Old Feb 18, 2005 | 01:05 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Originally posted by NismoGCoupe
I just dont understand it I hate troubleshooting, it was playing fine this morning when I bumping it I guess because I lowered the gains to less than half way last night but if I go above the half way on the gain it starts happening again.
another question for you guys on the radio setting what would be my best bet with setting the LOUD to? I have an option to have it OFF-LOW-MED-HIGH, med sound to low but high sounds to harsh
what deck is it?
LOUD is a setting I hate more than any other...it screams cheap peice of crap to me. It boosts the low and high frequencies
Old Feb 18, 2005 | 03:44 PM
NismoGCoupe's Avatar
NismoGCoupe
Pioneer DEH-P8500MP
http://www.pioneerelectronics.com/pn...etailComponent
btw I just put those grounding terminals in and im about 90% sure that was the problem , I can now adjust the gain without any crackling but I will not be sure until tomorrow I still haven't tried raising the volume to see if they cut out yet
Old Feb 18, 2005 | 03:46 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
look up in your manual how to use the EQ and tune as such, the loud feature is crap...
you want things to sound as even as possible to your ears
Old Feb 18, 2005 | 03:48 PM
NismoGCoupe
so should I turn it off? or keep it at low or med and start adjusting from there?
Old Feb 18, 2005 | 04:21 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
I would turn it off
Old Feb 18, 2005 | 05:51 PM
NismoGCoupe
Ashmo & TeesZ
Thanks for your help, the problem was definetly bad grounding for that one amp I can turn the volume all the way up now without the amp cutting off on me.
Ashmo, I did what you said I took the LOUD OFF and I deceided to raise the gain on the amps a little more and started adjusting the settings, all I have to say is I havent heard the DA Hex's shine until a few minutes ago these speakers are F***ing Loud and Clear, now that the LOUD is turned off, my ear are still ringing. Before when I had the LOUD on, the Hex's did sound good but only to a certain point then they began to get really harsh.
I always thought the LOUD setting should be on but it sound so much better with it off with the right settings, I'll be doing some more tweaking tomorrow.
Thanks again for your help
Old Feb 18, 2005 | 05:57 PM
TeesZ's Avatar
TeesZ
a LOUDNESS button is used to compensate for the human ear at low volumes. in theory, the loudness boost (at the highs and the lows) should attenuate as the volume increases. So, its not a "bad" thing necessarily.
Old Feb 18, 2005 | 06:02 PM
NismoGCoupe
I dont think its bad but with it off now I was able to hear the fully potential of these speakers without them being so harsh
Old Feb 18, 2005 | 06:09 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
didnt realize it was that advanced, makes sense
Awsome NismoGCoupe, glad you figuered your problem out! Glad also that the speakers are as pleasing to you as you expect them to be!
Old Feb 23, 2005 | 06:00 AM
NismoGCoupe
its looks like the problem is still occuring, my next guess is the amp are getting starved from power
Old Feb 23, 2005 | 07:47 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
that would be the next logical conclusion
Old May 19, 2006 | 12:42 PM
StillAlive2029's Avatar
StillAlive2029
did you get this fixed? was it needing more power??
Old May 22, 2006 | 08:19 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
why did you bring this thread back from the dead
kyin
Oct 15, 2015 05:54 AM
Alexreyes
Sep 30, 2015 11:30 PM
