Mounting crossovers in doors?
Old Feb 28, 2005 | 04:44 PM
Art Vandaleigh's Avatar
Art Vandaleigh
Default Mounting crossovers in doors?
Got a set of Infinity Kappa 6.5" components on the way, and would like to know how some of you guys with comp sets up front have mounted your crossovers in the doors? Any location/method best to secure them? Also, are the tweeters easy to replace into the stock location, or is some modification needed?
Old Mar 1, 2005 | 05:04 AM
ezee's Avatar
ezee
The tweeters are easy to replace, just remove the stock tweeter from the connecting plate, secure the new tweeter to the plate, and reinstall the plate. I used plastic tie wraps to secure each crossover to the existing wires in the doors.
Old Mar 1, 2005 | 07:28 AM
ezee's Avatar
ezee
If you replace the 3/4" stock tweeter with a 1" tweeter it will fit just fine.
Old Mar 1, 2005 | 01:50 PM
ezee's Avatar
ezee
I installed Infinity 10.2T 1" tweeters, they did not require a bigger hole.
Old Mar 1, 2005 | 02:35 PM
Art Vandaleigh
Fantastic writeup dave, that should help me out a lot. The kappa tweeters are 1", so hopefully they wont require much if any cutting in the stock location. Maybe the Perfect tweeters you have are different? Either way thanks for some help guys, and any other suggestions will be appreciated.
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
