Popping Noise - Help!!!
Old Mar 5, 2005 | 10:10 PM
SCRoadster's Avatar
SCRoadster
Default Popping Noise - Help!!!
I'm getting a popping noise from my left rear speaker.
This happens when I startup the car in the morning or starting after an hour or two of being parked.
The popping noise then goes away after 5-10 minutes.
I removed the RCA from the HU to the amp & the speaker still pops.
Installed a ground loop isolator but the popping's still there & caused engine whine.
My setup:
Stock Bose/NAV
PAC OEM
JL 450/4 amp
JL XR-650's F&R
Infinity BassLink
Help!!!
Old Mar 5, 2005 | 10:45 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
left rear...
sounds like amp trouble with no pre-amp source...
Old Mar 6, 2005 | 09:10 PM
dannichols's Avatar
dannichols
I was getting strange noises like that (pops and crackles) from my amp too. Turned out to be the wiring. Check your power, ground and even speaker connections at the amp. Ensure you have stripped enough insulation to get a good connection.
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
