Too much power for stock alternator?
Old Apr 22, 2005 | 08:55 AM
pulpz2's Avatar
pulpz2
Default Too much power for stock alternator?
I'm installing the following:
330x2 amp for subwoofer
70x4 amp (bridged) for front speekers
26x4 headuint (not-brideged) for rear speakers
Total system power will be 1044 watts. This will require ~75 amps total current.
Anybody have problems running of the stock alternator? I think it's rated at 110 amps.
Crutchfield assumes 0.4 x110 amps = 44 amps available. Then they suggest dividing this by 2 for a safe load so that's only 22 amps.
What's the best thing to do?
Old Apr 22, 2005 | 09:00 AM
tacomaboy's Avatar
tacomaboy
You should be fine...
I have a Zeus 1000D which is 1000 wattsx1 RMS @ 1 ohm (class D though) and a Zeus 6400 85wattsx4 RMS @ 4 ohms or 175x2@4 ohms (which is how I have it). Total of 1350 watts RMS, and I have *Barely* any dimming... and that I contribute to not having upgraded the big 3. I do have a 1fd cap though.
Old Apr 22, 2005 | 02:17 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Im running 2200 watts you should be fine
Old Apr 22, 2005 | 04:16 PM
JimRHIT's Avatar
JimRHIT
I've been on 2kw for almost 2 years now ... no upgrades needed, you'll be fine
Old Apr 23, 2005 | 08:44 AM
pulpz2's Avatar
pulpz2
Ahsmo, JimRHIWT,
are you guys using a cap or no?
I bought a 1.2 F cap.
Old Apr 23, 2005 | 10:01 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
nope,
cap can cut down on alternator whine thou..... but it can also hurt you power system.
Old Apr 24, 2005 | 06:29 AM
pulpz2's Avatar
pulpz2
Originally Posted by Ahsmo
nope,
hmmm, you're making me rethink the cap. I've already bolted it into my car but I haven't powered it up yet. What damage can it do to the power system?
Old Apr 24, 2005 | 11:41 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
not like physically screw things up.
More like, once the cap is spent, the alternator has to now charge the cap and power the amps...not to mention the rest of the car: gauges and other unimportant things like spark plugs.
Basically its just one more thing for the charging system to stress over.
Old Apr 24, 2005 | 01:24 PM
pulpz2's Avatar
pulpz2
OK, thanks for the advice.
Old Apr 24, 2005 | 01:46 PM
NissanZfan's Avatar
NissanZfan
How about a capacitor, not sure if that would help.
Old Apr 24, 2005 | 01:56 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Old Apr 24, 2005 | 09:55 PM
stu46's Avatar
stu46
^^lol
Old Apr 24, 2005 | 10:10 PM
supsup's Avatar
supsup
Newbie
just wonder..
how much will a bigger or better alternator cost for our car???
also why do they even make cap when it is not so good for the system?
and i do see many ppl have it in their car too!
not try to make an argument here
i am in the position of buyin a cap too..wanna make sure if i should buy it or not!
thanks for the help!
Old Apr 24, 2005 | 10:20 PM
stu46's Avatar
stu46
On a Civic with 2000 watts rms, put a cap.
A 350z with 2000 watts rms, looks.
Old Apr 24, 2005 | 11:51 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
few hundred bucks, there is a fellow around the great lakes that custom builds alternators for car stereos... I can get his name if you like
Old Apr 25, 2005 | 10:20 AM
NissanZfan's Avatar
NissanZfan
It kinda makes since, because a capacitor stores power when demanded, which delivers power when needed. Maybe power that your amp might need to run the stereo when turned up.
Old Apr 25, 2005 | 11:13 AM
pulpz2's Avatar
pulpz2
I don't think he disagrees with you in principle. But I think he was a bit confused about your suggestion because we were already discussing the usefulness of capacitors ( caps).
Old Apr 25, 2005 | 03:11 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Exactly!
derekinthez
South East
Sep 28, 2015 06:35 PM
