AVIC-N2 installed today.Couple questions.
Old May 13, 2005 | 01:40 PM
  #41
SteveZ33's Avatar
SteveZ33
Originally Posted by smoothludey
the screen is very floppy, especially when you use the touch screen it just bounces back and forth,
No it doesn't
where as the double din screen is solidly anchored with the option to angle the screen (can't angle the N2 screen).
Yes you can. And it also has memory to return back to whatever angle you had it set at when it's shut down then turned back on again.
Old May 13, 2005 | 01:54 PM
  #42
smoothludey's Avatar
smoothludey
Originally Posted by Apexi350z
smoothludey, got any pics?
where can one get the AVIC-D1 reasonable price?
I will get pics up asap....I got a great deal on the D1 online for $1299 at www.jjielectronics.com
Old May 13, 2005 | 01:59 PM
  #43
smoothludey
Originally Posted by SteveZ33
No it doesn't
Well, i've played with several floor models and the monitor just doesn't seem very stable, which may be the case for most of the flip out monitors. I just feel in a sports car like the Z, something that's not 'anchored' is bound to fly off especially when you're taking hard corners. I might be wrong though, but it just doesn't seem stable enough. Even though the D1 isn't a perfect fit for the double din space, it just makes sense to me to make the most of the enormous space left behind by the stock HU.
Old May 13, 2005 | 02:13 PM
  #44
SteveZ33's Avatar
SteveZ33
smoothludey, the D1 is a nice unit. I came real close to getting that first. But I decided to go with the N2 which I'm very happy with. I found the flush mounted screen on the D1 very attractive. But did not like how low it was mounted in the stock radio position. The N2, for me, is positioned at just the right height. Above the radio position, and below the stock NAV cubby. Hey, good luck with your customize bracket for a better flush mount look. I hope it works out for you.
Old May 14, 2005 | 08:07 AM
  #45
smoothludey
Default Avic D1 pics as promised...
let me know what you guys think...i know it looks ghetto right now.
http://www.pbase.com/smoothludey/inbox
Old May 14, 2005 | 01:05 PM
  #46
SteveZ33's Avatar
SteveZ33
Couple more pic. Sorry about the size, hope they load up for everyone. Don't worry, I won't post anymore after this
Old May 14, 2005 | 01:08 PM
  #47
SteveZ33's Avatar
SteveZ33
It's getting there smoothludey, keep up the good work !!!! Keep us posted with more pictures.
Old May 14, 2005 | 02:52 PM
  #48
Paul350Z's Avatar
Paul350Z
Living in 350Z
No trim bezel?
Old May 16, 2005 | 08:36 AM
  #49
got turbo?'s Avatar
got turbo?
Thank you for the pics, steve, and smooth. I have a question for steve. I want to have N2 install in the bottom pocket of the double din, and have a screen in the nav pocket, do you think the N2 will block part of the screen?
Old May 16, 2005 | 03:40 PM
  #50
SteveZ33's Avatar
SteveZ33
I just went out and measured the N2 as if it were mounted in the empty storage slot (as you can see in my pictures) below the unit. The screen + frame measures about 5" high. So I would say YES, with the screen in the out and up position, it will block the view of anything mounted in the stock nav pocket. It almost completely covers it now the way mine is set-up. Not only that, you may have a problem with the screen hitting the shifter when it's trying to pop out then up when mounted that low. Just my opinion, but I hope it helps.
Steve
Old May 18, 2005 | 08:29 AM
  #51
got turbo?'s Avatar
got turbo?
Steve
Thank you Steve. I guest I have to find a different place to put the screen, or get a AVIC-D1.
Old May 19, 2005 | 08:43 AM
  #52
Paikuhan's Avatar
Paikuhan
Any of you guys have a schematic and diagrams of the location of the 350Z's computer? I just got an AVIC-N2 and need to know where to hook up the speed sensor line + others.
Thanks
nanotech
Oct 2, 2015 05:02 AM
Li1ag
Sep 28, 2015 02:07 PM
