amp in the pocket behind the passenger seat. any downside?
Old May 22, 2005 | 11:15 PM
sharingan625's Avatar
sharingan625
Default amp in the pocket behind the passenger seat. any downside?
my amp, nine.1 is little too big to fit in the glove compartment behind the passenger seat, so i was playing around with it and decided to just keep it in the pocket behind the passenger seat. it fits in there very tight, and is as stealthy as being in the glove box. no heat issues, easy install.
any downside you guys can think of about this idea?
Old May 22, 2005 | 11:32 PM
gsi's Avatar
gsi
no its ok but if you have to replace or upgrade the fule pump its going to ad a bit of work
Attached Thumbnails amp in the pocket behind the passenger seat.  any downside?-dsc01399.jpg
Old May 22, 2005 | 11:40 PM
sharingan625
what's a fuel pump got to do with anything? am i missing something?
Old May 22, 2005 | 11:47 PM
gsi's Avatar
gsi
no. it just that the acess to the fule pump is directly under where you are wanting to mont the amp. so i wouldent get to permenent with your mounting and be carefull when grounding your amp run the ground off to the side and use a short screw making shure not to hit the gas tank, good luck
Old May 22, 2005 | 11:48 PM
gsi's Avatar
gsi
sorry about the spelling its late.
Old May 23, 2005 | 12:00 AM
sharingan625
oh. i see.
thank you for the info~
Old May 23, 2005 | 08:00 AM
neur0sis's Avatar
neur0sis
Shouldn't be a problem... lots of us mount our amps in there.
Mine is mounted on a removable amp rack, so as gsi mentioned, I can get to the fuel pump if needed. The grounding is on a ground block in the glove box, secured to one of the metal tabs sticking down in the compartment. No drilling near the gas tank needed.
Old May 23, 2005 | 10:37 AM
Badfish25's Avatar
Badfish25
I have a nine.1 and a nine.2 in that pocket, running both for about a month now and no problems. Only down side is not showing off such classy looking amps.
Old May 23, 2005 | 10:42 AM
sharingan625
yeah. i might have to do the same thing. tho, im not sure how i should run the power wire to stock sub location. i already ran the power wire on the right side of the car. is there some kind of opening to feed the wire in there?
Old May 23, 2005 | 11:38 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I put my amp in there with a shelf similar to neur0sis, for the back though I used a 170mm long bolt with some fender washers to hang the back end of the shelf.
The passenger and drivers sides of this compartment are all connected, if you have power to the passenger side you can easily pass it though to the drivers side.
Chris
Old May 23, 2005 | 01:07 PM
sharingan625
yay. aright. thank you very much!
Old May 23, 2005 | 01:27 PM
neur0sis's Avatar
neur0sis
As far as getting the power through from the passenger side, to the drivers side, I did this:
The fuse block for power and ground in the glove box "secret compartment" and ran the two 8ga leads through one of the several holes in the bracing between the compartments. No problems at all!
Old May 24, 2005 | 10:23 AM
sharingan625
thank you.
nice install btw.
Old May 24, 2005 | 10:24 AM
tacomaboy's Avatar
tacomaboy
YAY ED nine.1!
How do you like it? I have a eDi 6500 pair and an eD 12A as well as eDeadv1SE
BTW I have my amps placed here:
Old May 24, 2005 | 02:00 PM
Badfish25's Avatar
Badfish25
I really need to get around to installing my 6500's, I got them from the PRE-order, but have been switching cars ever since I got em. Only listned to them for like 2 days before I took them out and sold my old car.
I love my nine.1 thing is built like a tank and sound is awesome with it ran to a single 12v.2. I do miss those flat cone 12a's though.
Old May 24, 2005 | 02:51 PM
sharingan625
Originally Posted by tacomaboy
YAY ED nine.1!
i am dying to find out. i waited 6 month for my 11ov2s, and now the HU i wanna get is out of stock everywhere...
i love the appearance of nine.1 tho. so simple and beautiful. it looks so good, it makes me don't wanna do stealth install.
Old May 24, 2005 | 02:52 PM
sharingan625
yes. those flat cones were beautiful.
Rev_Night
Nov 7, 2020 06:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
kyin
Oct 15, 2015 05:54 AM
samansharif
Sep 25, 2015 12:31 PM
