sirius reciever static, HELP.....
Old Jun 20, 2005 | 06:12 PM
Christopher's Avatar
Christopher
Default sirius reciever static, HELP.....
My fuggin sirius reciever is static-e as *****, how do i stop the static, my antenna is on the roof about 5inches from the back window, on metal on teh roof, and the fm wire inside is just dangling loose, am i suppose to connect it to something ?
Old Jun 20, 2005 | 07:49 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
It is IMPOSSIBLE for digital radio to have static!
You either have enough bits to make music or not. It's called the digital cliff. You can get music gaps or chirps depending on how the co-deck is written but no static. So that means the problem isn't with the satellite antenna but rather with something internal.
I would check your connections between your Sirius receiver and your FM radio. Typically the car's normal AM/FM radio into the Sirius radio and then there's a cable that runs the signal out from the satellite radio and then into your AM/FM radio.
I would suggest that you read the radio's instruction manual to help identify the cables and where they go.
Old Jun 21, 2005 | 07:51 AM
dannichols's Avatar
dannichols
Which Sirius unit are you using..I'm assuming one with an FM modulator? Have you tried changing the transmit freq to another one?
Old Jun 24, 2005 | 09:47 AM
Nihility's Avatar
Nihility
Sounds like you're using a sirius receiver with the wireless FM modulator. Try the wired FM modulator that Directed makes.
Old Jun 24, 2005 | 09:50 AM
dannichols's Avatar
dannichols
naw, I'm using the wired one that links in to the Kenwood Excelen head units. I don't prefer low-bandwidth, streamed, digitized, mashed, fake music..but that's just me :-)
sammythebull
Sep 24, 2002 03:32 PM
Lee3Z
Aug 1, 2002 04:48 AM
JmanZ
Jun 4, 2002 11:00 AM
