RE Audio XXX
Old Jul 3, 2005 | 09:29 AM
umzzz's Avatar
umzzz
Cwest Army
Default RE Audio XXX
I called RE and asked them about the mounting depth for a 10" XXX. Its about 7.25 inches. Anyone know if that will fit in one of the ebay under strut boxes? I know it will fit mounting diamater-wise but depthwise anyone know?
Thanks
Old Jul 4, 2005 | 01:34 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
I measured staight back at a 90 degree angle from the exact center of one of the two holes in my Zenclosure box and measured 7 5/8". The top of the hole measures just 5 5/8 inches back, the bottom measures 9 inches so depending on the diameter of your magnet you're going to bump the top against the inside of the front wall.
You could go with a slight spacer to get the thing to fit hard pressed.
PS - I just noticed that there are now two different boxes for sale on ebay. The one I have is $99 and is from Zenclosures. There is now a second one for $154 from SoundOffAudio.
Old Jul 5, 2005 | 09:01 AM
JimRHIT's Avatar
JimRHIT
If it doesn't fit flush, you can always make a spacer ring to make it so that it fits.
Old Jul 5, 2005 | 11:51 AM
GQ 350z's Avatar
GQ 350z
Don't you want to keep at least .25"-.5" from the end of the speaker to the beginning of the box to eliminate interior harmonic distortion?
I always thought this was a small yet important measurement. You will have space since 5/8 > .25, so yeah. Use a small trim riing in order to space it a bit, just make sure to seal it off nicely.
ravi
Old Jul 5, 2005 | 11:57 AM
lil ze's Avatar
lil ze
What are the specs on that XXX 10" ?
Old Jul 5, 2005 | 12:03 PM
umzzz's Avatar
umzzz
Cwest Army
ravi
what kind of spacer would i need and how would i go about sealing it up? i really want to make this set up work and i really want it under the strut bar!
I heard the RE XXX in a friends car a while ago and its simply phenominal. Clean solid bass just the way i like it!
Old Jul 5, 2005 | 12:10 PM
GQ 350z's Avatar
GQ 350z
Yah, I used to own a 15" version of it. I might try to fit in a single 12, that will be devestating bass bro! Ahahah
Anywho, imagine a mdf circle that is x inches thick, and has the same circumference as your sub. Its very typical, go to your local audio shop for any questions. You can use any typical sealer such as silicone to make sure the box is sealed off. Also, make sure to have bracing and have them make the front baffle at least 1" thick. The sub ways something like 50 lbs, so you dont want any destruction back there haha.
ravi
Old Jul 5, 2005 | 12:20 PM
JimRHIT's Avatar
JimRHIT
You really want to have about 1" of free airspace behind the driver like this.
Basically, since the polepiece is vented, you change the compliance of the driver by plugging it, as well as take away from the benefits of the venting. Essentially the cooling effects are taken away...so thermal compression sets in sooner.
I would make the ring out of a say 18 x 11 x 1 oval shape piece of MDF with the 10" cutout for the driver in the center ... then roundover the edges. I'd mount it on with about 15 countersunk screws, bondo it ... and paint ... or carpet in this case.
Essentially, it would be a cosmetic trim piece that also acts as a nice spacer too. I think it coul be make to look pretty nice.
- jim
Old Jul 5, 2005 | 06:35 PM
umzzz's Avatar
umzzz
Cwest Army
sweet thanks a lot guys
jlb
Oct 15, 2017 05:10 AM
bcoffee20
Nov 19, 2015 06:39 PM
bneumann
Oct 7, 2015 12:16 PM
