im so dumb!!
Old Jul 19, 2005 | 05:50 AM
umzzz's Avatar
umzzz
Cwest Army
Default im so dumb!!
aright so i installed my speakers into the doors up front...ran the wire through the doors and everything but i forgot to mark which wire is the tweeter and which is the midbass
so i was thinking that i could just hook up the speakers and see which one i get sound from and that way i will know which speaker wire goes to which.
my question is that will i blow anything if i hook up ther tweeter wire to the midbass or the midbass to the tweeter when i try and figure out which wire is which?
im so dumb but any help is appreciated
thanks guys
Old Jul 19, 2005 | 05:55 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
thanks guys
Yes this will work, just keep the volume to reasonable levels.
Another trick is to use a 9 volt battery and just touch the speaker wires to the (+) and (-) terminals. You will get a pop from each speaker as you touch the wires with it. You can also use the 9 volt battery to check the polarity on the midbass and subwoofer. When you get positive to positive and negative to negative the speaker cone will pop outwards into the car - if you get it backwards the cone will suck back into the spider away from the inside of the car. The tweeter cone can be hard to check this way but it will work on dome tweeters a bit.
Old Jul 19, 2005 | 06:02 AM
umzzz's Avatar
umzzz
Cwest Army
i actually know the positive and negative orientation on the wires...the positive wiring has writing on it and the negative doesnt...i just didnt keep track of which set go to which
Old Jul 19, 2005 | 07:00 AM
xNeo's Avatar
xNeo
Yup, just use the 9 volt battery... works like a charm!
Old Jul 19, 2005 | 09:09 AM
umzzz's Avatar
umzzz
Cwest Army
thanks guys
Dr.Paulyy
Jul 29, 2019 07:45 AM
Alexreyes
Sep 30, 2015 11:30 PM
rizzla
Sep 29, 2015 03:58 PM
shoalhaven
Oct 1, 2002 07:14 PM
