Area to run amp wire from battery to trunk
Old Aug 6, 2005 | 08:43 AM
nissansource's Avatar
nissansource
Default Area to run amp wire from battery to trunk
I honstly havnt looked at my car yet but im doing a full install on the stereo. I need possibly an aid as to were everyone is running their power from the battery and what portion in the firewall are you guiding the amp wire though??
Old Aug 6, 2005 | 08:55 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Pull the plastic frame out from around the battery by pulling up a handful of those press-to-lock fasteners. Then look behind your battery on the far out side for a nice large rubber gasket where the stock cables fit through.
If you go straight back from the negative terminal and down about four inches you'll find it.
Old Aug 7, 2005 | 06:28 AM
LS350Z's Avatar
LS350Z
Charter Member #56
Here's my run.
Battery - fuse (just left of the battery) - through ECU wire bundle (where Paul described) - along passanger kickpanel under carpet (hides real nice) - under glovebox - through hole already in trunk area (obviously I put a rubber gasket around the area)
Old Aug 7, 2005 | 04:42 PM
momo 350z's Avatar
momo 350z
or you can get a little fancy and do it like i did...drill a hole threw the side and run it along the drivers side foot well[IMG][/IMG]
kyin
Oct 15, 2015 05:54 AM
nanotech
Oct 2, 2015 05:02 AM
