So frustrated with Audio I just needed to vent
Old Aug 7, 2005 | 06:06 PM
SRT4 to 350Z's Avatar
SRT4 to 350Z
Default So frustrated with Audio I just needed to vent
Well I finally completed my complete alpine system on friday. Alpine CDA-9835 HU, new type X components, blank rears, MRD-m605 mono block to one 10 type R under the strut, and a MRP-f345 powering my interiors.
Just finished up the system on friday, and i already blew the drivers door speaker, and I blew the sub as well. I can't believe that i blew them already, it sounded amazing for like 2 days, and now it just sounds like garbage. When the sub hits, it doesn't sound deep at all, and when the speakers get cranked up, they sound like muddy ***. I'm just pissed, now i'm going to have to take everything out, send it back because i bought it over the internet and then get replacements... This sucks
Old Aug 7, 2005 | 07:09 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Your woofer wasn't even broken in before you broke it. It generally takes a good 50 hours or so before they hit their prime.
Make sure that you've matched your headend to your amplifier's gain and that you're not clipping.
Old Aug 8, 2005 | 07:53 AM
ANXIOUZ's Avatar
ANXIOUZ
Well, congrats on blowing a Type-R. I didn't think was possible. Impressive....but how freaking loud do you listen to your music!?!?
Old Aug 8, 2005 | 08:06 AM
03Black350Z's Avatar
03Black350Z
Check your gains!!!(however the sub can handle 500w rms and your amp only gives out 400w rms at 4ohms), also check your power and grounds to make sure they are good.
Old Aug 8, 2005 | 10:08 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Thanks for the numbers. A 400 W amp can blow a 500 W speaker with enough cliping for long enough. When an amp clips it sents out square waves - an infinite number of odd ordered hamonics - which is engineering speak to describe a perfect square wave. What the amp does is send out frequencies 3x, 5x, 7x higher than the original frequency which is clipping. Clipping sends out frequencies not in the music and not for reproduction!
Clipping kills speakers.
In a nice sounding sine wave the speaker's cone moves in and out never really pausing at the top or the bottom. It disapates - it uses up - about 10% of the wattage moving the coil back and forth making music. The other 90% is used to heat that coil up. In clipping the speaker pauses at the top and the bottom of it's movement soaking up that DC voltage as 100% heating - not moving the coil at all for that brief moment.
Back when I worked in the business I saw lots of 40 W equalizers eat 100 W speakers. Crank that 40 Hz **** all the way clockwise and let the clipping begin. We'd replace the speakers under warranty twice and then tell the clown he was on his own!
Old Aug 8, 2005 | 02:24 PM
SRT4 to 350Z
Don't get me wrong, I pushed the heck out of my system... Tweeter reccomended listening to the sub at +7 setting on my alpine unit... Well the bass freak I am, I turned it all the way to +15 and sure enough, it blew like all hell. As for the type X components, they suck.
Old Aug 10, 2005 | 07:41 AM
jdohman's Avatar
jdohman
Did you get the stuff online or did you get it from a dealer?
Old Aug 10, 2005 | 09:25 PM
SRT4 to 350Z
i bought everything online... HUGE mistake... definitely worth paying the extra buck to buy it from a stereo shop... I learned my lesson the hard way;.
Old Aug 11, 2005 | 08:47 AM
Nazar's Avatar
Nazar
I am sure you have already done this, But make sure the crossovers are adjusted properly for th efront speakers. Start from 80HZ Hi-Pass and tune it from there. You do not want to run full range signal to your Type-R Speakers.
When you set the gain for your Sub amp Turn your deck Sub level to +15 Then tune it accordingly. Alpine receivers are set up as an attenuater, So when you turn it reduces the signal. You want to get it to where you like it best at +15, you can always turn it down with other songs. This way you won't maximize your potential to blow your sub. Also check the settings of the crossovers in the sub amp.
Old Aug 11, 2005 | 02:57 PM
SRT4 to 350Z
I'm running the new type-X components... Not the Type-R's..
Old Aug 12, 2005 | 05:43 AM
Nazar's Avatar
Nazar
Ahhh, My appologies. Well, Same rules apply, Except you will need to cross them over at a higher frequency.
Type X was not designed to take a beating. They are more of a sound Q speakers. Type R takes a lot more beating.
Old Aug 12, 2005 | 10:11 AM
james840a's Avatar
james840a
Make sure you have your V12 amps gains match alpine 4.0v pre amp out put or you are going to blow the subs with to much clipping. I have the 9855, MRD-M605 10 type S and a MRP-F345.
These are digital amps, not the old style analog.
sherm
Apr 11, 2020 05:21 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
