Box Filler
Old Aug 16, 2005 | 10:30 AM
umzzz's Avatar
umzzz
Cwest Army
Default Box Filler
What are you guys using to fill your sub boxes. I ordered one of mikes boxes but its a little bigger than my sub calls for. I need .5cu of space but the box has .75cu. Polyfil...? or something else?
Tried searching but didnt really come across it..
thanks
Old Aug 16, 2005 | 10:38 AM
JCat's Avatar
JCat
I went to the sewing/material dept. at WallMart and bot pillow stuffing (polyfill).
I glued it to the inside walls of the box with spray 3M glue.
Definately noticed that the subs hit lower and harder.
Old Aug 16, 2005 | 11:05 AM
umzzz's Avatar
umzzz
Cwest Army
nice...thanks
Old Aug 16, 2005 | 12:00 PM
03'350z's Avatar
03'350z
Thats What I Use Also, Though I Just Stuffed It In Leaving Enough Are For The Sub
Old Aug 16, 2005 | 12:54 PM
THEDUKE's Avatar
THEDUKE
When you stuff an enclousure with polyfill it makes the woofer act as if it is an a larger enclousure. What you want to do is make the enclousre smaller. The bets thing you can do is add pieces if wood inside and make sure they are glued very well or screwed in so they do not become loose or vibrate inside the box.
Old Aug 16, 2005 | 01:10 PM
umzzz's Avatar
umzzz
Cwest Army
Thats what a friend of mine said also...i was thinking of just using 3m spray adhesive and 2x4 peices to get the volume down...does it matter where in the box you put the 2x4s?
Old Aug 16, 2005 | 01:15 PM
sharingan625's Avatar
sharingan625
Originally Posted by umzzz
nice...thanks
if the box is for your ov.2, .75 is perfect size. .5 is the minimumi think. i would actually want it a little bigger... you don't need to make it smaller.
i wish i had a 2qf enclosure for my ov.2s.
good luck!
Old Aug 17, 2005 | 08:25 PM
NisAznMonk's Avatar
NisAznMonk
If its a sealed box, no it won't matter.
Old Aug 17, 2005 | 08:52 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Thumbs up
+1 glue and screws - lots of both and proper ones. There's a lot of energy being bantered about on the inside of a subwoofer. I would use a carpenter's yellow glue as I've known the wood to give out before that stuff. I want the glue pouring out from around all sides of the wood.
I would also run wood screws (not sheet metal, not pasterboard) through the 2x4 and deep into the box of the subwoofer. You could even crossbrace using dimentional lumber to gain something from the added wood. The screws will hold the wood in place until the glue sets up.
Glad to see that you're actually sizing your driver to the box.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
