Question for the Audio Guru
Old Sep 7, 2005 | 04:03 PM
TxTitan's Avatar
TxTitan
Default Question for the Audio Guru
I'm going to intall 3 subs and 3 amps. Do I use a rca spliter or something to connect the 3 sub amps to the headunit?
Thx,
Old Sep 7, 2005 | 06:58 PM
poormanq45's Avatar
poormanq45
yep, you use as manner splitters as you need to get the number of rca outputs that you need.
Old Sep 7, 2005 | 07:00 PM
khsonic03's Avatar
khsonic03
PoormanQ45--don't you post at the12volt.com? I remember seeing your posts over there. You have a Z too?
In response to the question at hand, you can also use pre-amp outputs if the amps have them.
Old Sep 7, 2005 | 07:06 PM
KenWH's Avatar
KenWH
Some amps are daisy-chainable(have rca outputs). Bascially that allows you to run one set of rca's to the amp rack.
Edit:
Sounds like your putting together a pretty serious bass setup.
What kind of line voltage does the headunit put out? If your amps don't have rca outs...and/or your h/u line voltage is less than 4volts rms...I'd considering running a line-driver. Phoenix Gold's PLD or Audio Control's Overdrive are nice line drivers. Probably some other brands are available but I've used these two with good results. The overdrive will give you a little more voltage than the PG so I'd go with it They run around $100 or so.
Line-drivers were very common back years ago before high voltage h/u's were common(cheap) and are still useful today when your install requires "watering down" of the line signal by splitters, etc. Plus most "high- voltage" h/u's don't put out near the advertised voltage as rms.
If you do use one...be sure to mount it behind the h/u and run as short rca cable as possible to it.
Old Sep 7, 2005 | 07:40 PM
KenWH's Avatar
KenWH
Tx,
After looking at your sig...I take it your still running the bose h/u.
If so, i assume your running line coverter. If your running the bose h/u and will be trying to feed 3 or more amps off it...i'd really consider a line driver. Mount it as close to the converter as possible.
Note: I've never run a line driver with a line converter in front of it so I don't exactly know how it will react as far as line noise though. I'd say if your not noticing any line noise now...you'd probably be ok.
Old Sep 8, 2005 | 07:42 AM
JimRHIT's Avatar
JimRHIT
why not use one amp and series-parallel combo the sub wiring. Cheaper, and you can probably get more out of your amp with a lower load from the subs.
just a thought...
Old Sep 8, 2005 | 08:00 AM
Nazar's Avatar
Nazar
If you are using 3 amps with 3 subs, make sure your subs are in seperate enclosures.
Old Sep 8, 2005 | 10:05 AM
TxTitan's Avatar
TxTitan
Maybe this will help; I should have posted it before. I'll be adding this to my current configuration and I will be replacing the stock Bose H/U. Thanks for all the suggestions so far. I'm going to look into the RCA in/out on the amps that seems like a slick way to do it if it's supported. Anyway here are my system components (All comments appreciated good or bad )
H/U Kenwood Excelon DDX8017
3-12" P5 1600watt sony xplod subs
3-1600watt P5 monoD sony amps
1-Pioneer gmx924
4 earthquake 6.5 speakers 400 w RMS (stock location)
2 tweeters with crossovers (stock location)
1 DHD ntx-6200 crossover
Specifications: 1-Pioneer gmx924
• Continuous Power (20Hz-20kHz, 0.08% THD)
• 4 ch: (4 Ohm) 65Wx4
• 4 ch: (2 Ohm) 75Wx4
• 2 ch: (4 Ohm) 150Wx2
• Maximum Power (EIAJ)
• 4 ch: (4 Ohm) 130Wx4
• 2 ch: (4 Ohm) 300Wx2
• Frequency Response: 10Hz - 50kHz (0,-1dB)
• Total Harmonic Distortion: 0.003% (1kHz, 4 Ohm)
• Signal-to-Noise Ratio: 105dB (IHF-A Weighted, at 1kHz)
• Dimensions: 10" x 2-3/8" x 12-3/8"
Features:
• Bridgeable 2/3/4 Channel Capability
• 1-Ohm Stable Operation
• Class A Circuitry
• PWM Regulated MOSFET Power Supply
• Balanced Isolator Input Circuit
• Gold-Plated Screw-Type Power/Ground Terminals
• Gold-Plated Screw-Type Speaker Terminals
• Gold-Plated RCA Inputs (x2)
• Gold-Plated RCA Outputs
• Hi-Volt Input Level Control (400mV-6.5V)
• Top Mount Controls
• Variable Crossovers: 50-120Hz, -12dB/oct. (LPF/HPF) (Front &
• Rear Channels)
• Dual-Fan Cooling
• Illuminated Logo
Specs: H/U Kenwood Excelon DDX8017
• 6.5 inch Wide color TFT Active Matrix Display
• Motorized Slide-down Front Panel
• Interactive Touchscreen Control with GUI
• Audio Easy Control Mode while Playing Visual Source
• Selectable Wall Paper (5 Patterns)
• Installer/Backup Memory of Audio/Video Setup
• Maximum Output Power : 50W x 4 (MOSFET Power IC)
• Gold Plated 5.1ch Preouts with 5V Pre-output Level (Front/ Rear/ Center/ Subwoofer)
• 2 RCA AV Inputs/ 1 RCA AV Output
• Video Input for Rear View Camera
• RGB Input for Navigation System
• Dolby Pro Logic II / dts surround
• SRS WOW / Circle Surround Automotive
• 4 Band Parametric EQ/ Digital X'over/ Listening Position Control
• DVD Menu Direct Touchscreen Control
• MPEG 1/2 Video files (.mpg) and JPEG files (.jpg) Playback
• Dual Zone Source & Volume Control
• DVD±R/RW Compatible
• External Media Control - iPod Ready
• Satellite Radio Ready: Yes
• Preamp Voltage: 5 volts
• Subwoofer Preamp Outputs: Yes
• Maximum Power: 50 Watts
• DIN: 2
• Changer Control: Yes
• CD Text: Yes
• Built-in EQ: Yes
• CD-R/CD-RW Compatible: Yes
• Remote Control: Yes
• Detachable Face: No
Sony Subs
Details:
» 12" subwoofer with two 4-ohm voice coils » aluminum cone with rubber surround » five-sided cone design » power range: 80-400 RMS watts (200 watts per voice coil) » peak power: 1400 watts » frequency response: 18-2500 Hz » sensitivity: 89 dB » mounting depth: 5-7/8" » sealed box volume: 1.15 cu. ft. » ported box volume: 0.82 cu. ft.
Sony amp for subs
Amplifier Type
Mono Channel
Bass Boost
With Bass Boost
Bridgable
Not Bridgable
Power Output
RMS Power at 2 Ohms 900 W x 1
RMS Power at 4 Ohms 500 W x 1
Performance
Frequency Response 5 Hz - 300 Hz
Low - Pass Frequency 50 Hz - 300 Hz
Bass Boost Frequency 40 Hz
THD at Rated RMS Power .06 %
Dimensions
Width 13.69 in.
Depth 13.38 in.
Height 2.25 in.
Other Features
Input Voltage 10.5 volt
MOSFET amp Yes
3 Way Ready No
Warranty
Warranty 1 Year
Miscellaneous
MPN xm-ds1600p5
Product ID 21854544
Release Date 23 February, 2004
Old Sep 8, 2005 | 11:19 AM
JimRHIT's Avatar
JimRHIT
all I am going to suggest is that you change the amp/sub combo. Please give me a budget to work with on replacing that and we can spec you out something ALOT better than that part. I am not a fan of earthquake, but for the money they will do just fine for the components.
- Jim
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
