speaker connectors for power wire?
Old Oct 4, 2005 | 09:00 PM
Takhteh's Avatar
Takhteh
Default speaker connectors for power wire?
this may be a silly ques, but can you use gold-plated speaker connectors to feed power wire to an amp?
Old Oct 5, 2005 | 05:46 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Sure why not?
As long as the connector matches the diameter of the wire - don't connect a 18-22 gauge connector onto the end of 4 gauge wire.
Old Oct 5, 2005 | 09:46 AM
Takhteh's Avatar
Takhteh
I'm actually trying to do something similar in my set-up...I have a 4awg power wire to feed my amp, but won't seem to fit the terminal. The amp only accepts 8awg wire or lesser widths apparently, but is fully capable of handling power from a 4awg...so I'm thinking about splicing the power wire right before the amp and placing lesser gauge, gold-plated speaker connectors on each end--this is the only way I see it to fit...Can this work? The terminal on the amp is set-up like the crimpless ring terminals- it has a hex screw you use to hold the wire in place. Please help!!
Old Oct 5, 2005 | 09:54 AM
NTRIGUE's Avatar
NTRIGUE
Sounds like a terrible idea. Just buy nice 8awg with firm properly fitting terminals.
Pleask
Dec 21, 2021 03:17 PM
350Z_Al
Oct 29, 2020 07:44 PM
3vilbunny
Jul 18, 2017 05:10 PM
