help installing Power Acoustik PT-700MHR
Old Oct 19, 2005 | 04:36 PM
FlorendoCruz's Avatar
FlorendoCruz
Default help installing Power Acoustik PT-700MHR
hey, i just bought a 7'' power acoustik PT-700MHR and im having trouble to how im going to fit the lcd on the stock Z cubby. Do i have to take off the dash and place the monitor from the back? Could anyone please help me with this install? Thanks
Old Oct 19, 2005 | 05:17 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Well if you have a 2004 or later and want a 7" screen to fit, the easy way is to get a 2003 cubby. Then you pull out the center console and trade cubbys. The 03 has a different finish than the rest so if you want to get creative you can pull the doors apart and switch the, but that is a little more involved.
I have not seen a 7" in a latter cubby yet, not to say it can't be done though, just have not seen it.
2003 cubbies are available at performance nissan.
Chris
Old Oct 19, 2005 | 05:23 PM
FlorendoCruz
i have a 03 Z. Can the 7'' fit in the cubby without takin the sliding door off? I want to be able to open and close the cubby while the lcd is in there. How can i insert the 7'' in the cubby? I tried installin it from the front but it jus wont fit right. Any suggestions?
Old Oct 19, 2005 | 05:34 PM
HyperSprite
Mad Scientist
Check out the pictures near the bottom of the right side, this is how I got my screen in. http://www.hypersprite.com/auto/tech-z-007/default.asp
The little box comes out from the back, then I used zip ties to hold it in. It's been in there a while and has not moved at all. It's solid.
Chris
Old Oct 19, 2005 | 05:50 PM
FlorendoCruz
thats sort of helped. How do u take off the center console? Wheres the damn screws or does it jus pop out with a lil force? From there, i think i can figure out how to put the monitor from looking at ur pics. Thanks a bunch man..
Old Oct 19, 2005 | 06:10 PM
HyperSprite
Mad Scientist
There is a "how to" some place on this site.
You actually start with the shifter boot/air controls piece by lifting it out of the way. Sort of stick you fingers into the boot and lift up on the trim towards you. To lift it up and turn it to the side, it is easier if the car is in Neutral or third. Disconnect the Air module from the shifter boot/air controls piece.
Then it reveals screws Two for the air module and two for the lower part of the console. I find it easier to pull out the air module first. Sort of a pain.
The middle screws are behind the bottom of the cubby so you need to take the lower trip piece off the cubby to get to those.
The top pulls away but it has the gauge wires so to get it more than a few inches you need to disconnect that.
You don't really need to pull the whole thing out but at that point you can if you want, I just put a towel on my shifter and leaned it into the car while I worked on it.
Chris
Old Oct 19, 2005 | 06:18 PM
FlorendoCruz
bingo!!! That helped alot. I know exactly wat to do now, well hopefully =D. That was a big help and thanks alot of everything. This forum rules cause of the poeple that are willing to help a fellow Z owner.
Old Oct 20, 2005 | 05:00 AM
Mike Wazowski's Avatar
Mike Wazowski
Post pics when you finish
Old Oct 20, 2005 | 05:17 PM
FlorendoCruz
wow...ok..it was harder than i thought... I managed to place the 7'' power acoustik lcd in stock cubby. I ran the wires and hid them perfectly. I didnt get to finish the install cause it got dark. I'm going have to start again tommorow morning. I had hard time getting power for the dvd player. Should i get the power from cigarette lighter or jus go straight from the battey? Does the cigarette lighter pop off cause i hard time getting it out so i can get access to the wires beneath it. Anyways, ima go try again in the morning and ill definetly have pics of the lcd and dvd player. Thanks for all ur help.
Old Oct 21, 2005 | 04:44 PM
FlorendoCruz
Default Problem....
i installed both the lcd and dvd player and i have my boss speakers connected to the dvd at station 88.9. The problem is that i hear a lot of static sounds when im playing movie. Is this normal? When i put it back to regular radio station or cd player, the static goes away. Is there something i could do to get rid of the static noise coming from the speakers?
Old Nov 12, 2005 | 07:20 AM
Cuore_alfa's Avatar
Cuore_alfa
where do you install the DVD i`m looking for a nice spot?
Old Nov 12, 2005 | 03:09 PM
FlorendoCruz
i installed the dvd player on the compartment behind the passengers seat. I made a bracket and concealed the DVD player on the compartment mat.
Old Jun 6, 2006 | 11:16 PM
ProfessorKan's Avatar
ProfessorKan
any pics?
codek
Sep 28, 2015 03:03 AM
