FM Reception
Old Nov 6, 2005 | 05:33 PM
350xfire's Avatar
350xfire
Default FM Reception
Anyone having trouble with FM reception with the stock antenna? Can anything be done to improve?
Old Nov 7, 2005 | 09:46 AM
VO...'s Avatar
VO...
Administrator
Need more info. Are you running a stock or aftermarket HU?
Old Nov 7, 2005 | 05:38 PM
350xfire's Avatar
350xfire
Aftermarket. It's kind of a cheap double din unit. It is a Valor brand DVD/AM/FM/CD...etc. Yes, I wanted the Eclipse or Kenwood or Pioneer, but wasn't willing to dish out more than I paid for my home 6.1 surround sound receiver for one of those. May be the antenna lead came loose when I stuffed everything back in.
Thanks
Old Nov 7, 2005 | 06:32 PM
boma's Avatar
boma
I just had this same problem. Hook up the Blue wire from the aftermarket harness into the Remote turn on wire for your head unit.
Even though our Z has a plastic antenna it needs this wire to turn on the antenna amplifier.
I mistakenly thought that wire was for cars with power antennaes.
Old Nov 7, 2005 | 07:26 PM
350xfire's Avatar
350xfire
Problem is that the antenna turn on only works when the AM or FM is used. If playing a DVD it is not powered so amps don't come on. I tried using it to begin with. I wonder if I could hook up both the constant power and the antenna leads together?
Old Nov 7, 2005 | 07:31 PM
boma's Avatar
boma
Why would you be using the Radio Reception while you're watching a DVD? I'm confused.
Old Nov 7, 2005 | 07:34 PM
350xfire's Avatar
350xfire
What I'm saying is that you cannot use the antenna cable to turn on amps since that cable is only hot when the tuner is used. If using DVD the cable is not hot so you can't run amps.
Old Nov 7, 2005 | 07:36 PM
350xfire's Avatar
350xfire
Wait! I see what the issue is. Just hook up the blue wire to the harness... OK, I'll try that. I re read the post and made more sense out of it.
Thanks
Old Nov 7, 2005 | 09:07 PM
boma's Avatar
boma
The Green wire with the white stripe on the factory harness should line up with the blue wire on the metra harness (or whatever brand).
Make sure that blue wire lines up with that green/white wire. That is the antenna amp turn on wire.
Old Nov 8, 2005 | 12:53 AM
dsmal's Avatar
dsmal
So this is necessary to get decent reception? I have a non-bose and i recently replaced my HU and my reception is bad also, so this should help?
Al
Old Nov 8, 2005 | 03:48 AM
350xfire's Avatar
350xfire
Al
I guess so, man. This is not what I wanted to hear since it will suck to have to take everything apart again. But, I guess now we know the problem and can fix it. At least it wasn't just a piece of crap head unit...
Old Nov 8, 2005 | 05:55 AM
suprpwr's Avatar
suprpwr
Interesting topic. I just installed my aftermarket and am getting bad reception. The thing is, I had two blue wires off my wiring harness -- one for the amp turn-on, one for the power antenna turn-on. Should I just connect both of them to the right place on the factory wiring harness?
Old Nov 8, 2005 | 07:22 AM
boma's Avatar
boma
Yes this is neccessary for non Bose too! Any Z that gets an aftermarket HU needs this wire hooked up.
I dont think you need the power antenna turn on. Just amp turn on.
Old Nov 8, 2005 | 07:39 AM
VO...'s Avatar
VO...
Administrator
Use the amp turn-on lead to trigger your amps. Run a separate "amp remote turn-on" wire to the amps. Connect the amp turn-on lead, from the back of your HU, to this wire.
Use the pwr antenna turn-on lead to turn the antenna booster on. Connect that lead to the pwr antenna booster lead, in the factory harness.
Old Nov 8, 2005 | 07:45 AM
VO...'s Avatar
VO...
Administrator
Are you sure of this? It sounds like you might have another remote lead that you over looked. Most HU with DVD capability will come equiped with two remote leads. One for the antenna and a separate one for the amps. Mine HU has both leads.
Old Dec 26, 2005 | 10:23 PM
Mendy9677's Avatar
Mendy9677
I seem to having the same problem as all of you. I bought ones of those cheap double-din dvds and i am having problems with my FM reception. I went back and tried to figure out the wires but it looks like i have it right. The green with the white stripe is lined up with the blue on the metra harness and I have that connected to the blue wire on the headunit (note their are no unused wires on the headunit). Any ideas? Did you guys get the problems figured out?
Old Dec 27, 2005 | 05:21 AM
Mendy9677's Avatar
Mendy9677
Help!
Old Dec 27, 2005 | 08:39 AM
boma's Avatar
boma
I'm not sure... someone help this man!
Old Dec 27, 2005 | 08:48 AM
TruBluZ's Avatar
TruBluZ
I have the same bad reception problem. Dang, I should be able to take the dash apart blindfolded by now. Hope the fix works boma!
Old Dec 27, 2005 | 09:17 AM
VO...'s Avatar
VO...
Administrator
Originally Posted by Mendy9677
Help!
supply 12vdc to the antenna power booster.
