Getting Sirius...which unit?
on
I want to get a unit that I can store in the center nav-cubby hole. Which receiver is the best for that?
Also, what's the difference between the regular receivers and the FM modulator ones? Don't they all go through the FM if you are using a stock non-sattelite stereo?
The Starmate Replay is a nice little unit and should fit in the nav cubby. I have one but have it mounted elsewhere as I have the factory nav. There are a couple of other small units available so depending upon if you're going to need them to be portable, you have several options.
I use an aux-in adapter rather than the FM modulator for the sound as I have the Bose unit with the sat capability.
I'm not clear on what you mean by a regular receiver..a satellite non-portable unit, maybe?. An FM modulator is a secondary unit that you'd use interface (hardwire) into your HU and the Sirius unit would plug into that. There is also the built-in wireless FM modulator from the Sirius portable units and it eliminates the hard-wired FM modulator. If you don't want to mess around with wiring, the wireless modulation may be a good alternative since less wires need to be hidden.
With a stock non-satellite ready HU, the playback options are limited but I've heard that the wireless FM modulators in the newer Sirius units provide a pretty clear sound.
From what I know, the only ways to interface with the HU is either by an aux-in adapter or FM modulation.
Siriusbackstage.com has tons of info and knowledgeable nice folks and may have more in-depth info to peruse for more specific questions too.
on
I was thinking about the starmate replay actually. I just didn't know if I just needed that or if I also had to buy the seperate FM modulator thing.
http://shop.sirius.com/edealinv/serv...dParentID=7871
That's what I wanted to get, I wouldn't need anything else right?
Right! You won't need anything else for your car. That little unit has the wireless FM modulator already built into itself. I have it and it's nice...the display is a bit bright though. It doesn't run hot like the earlier models. This one will easily slip into your pocket too if you need to take it anywhere. They have 'em at Circuit City and Best Buy if you want to go play with it a bit before you buy it. The rebate applies to any purchase of the unit whether it be from the sirius store or from a retailer. I liked it so much I bought a second one for a Christmas present.
I posted this info in another thread and thought you'd be interested, Act of God. (What a cool name, btw.) It'll save you a few more $$.
I got this in an email from Sirius...an additional 10% off and that's on top of the rebates. Here's the link: http://bm.sirius.com/ajtk/servlet/JJ...1&R=1356099541
It's valid until 11/30.
on
wow $66 bucks, that's hard to beat. I'm on it, thanks bro! I just hope it fits in the cubby
my screen name is my old high school band (Circa 1993-1994), we were "metal"...hahaha. We had songs called "satan", "mutilated pancreas", "spores of malaria" and "****".
good times, definitely miss those days
Just an FYI before you buy,
Satilite radios that use the FM channel don't sound as good. Basicly it's a digital to analog converter down grading the signal so you can hear it with your system.
on
I don't just want it in the Z though, so I will accept that. I don't drive the Z in the winter, I drive the civic. I was going to get a Sirius headunit but then i'd be confined to that one car. And I don't feel like buying multiple headunits.
can you connect it via aux?
on
Some of the units also offer a relay that plugs into the back of your radio in place of the FM antenna, then the FM antenna plugs into the back of the relay. The sound quality will be much better than an FM modulator bu not quite as good as AUX inputs.
Good luck,
I'm currently using an aux in adapter on my stock HU.
on
the new s50 unit should be out in the next couple of weeks.
S50
SIRIUS satellite radio/MP3/WMA player • stores 50 hours of SIRIUS content and digital music files • accessories for portable use (playback of MP3s, WMAs, and stored SIRIUS content) • car accessories include cradle, mount, DC power adapter, antenna • remote control • rechargeable battery • AC poweradapter
S50
on
My wife has the Sportster Replayin her Xterra, Not sure if it will go into the cubby but we use the FM modulator and it works great. She loves it. The Sporster has a little bigger display on it than the Starmate. Thats why we got it. Never had a problem with reseption.
on
I just got my starmate in the mail. This thing is tiny, I love it. It has an FM out and Audio slots. I would assume the Audio slot is where I could directly hook it up to AUX inputs on the deck?
Audiovox PNP 2 receiver w/ PAC AAI-NIS (vast improved sound quality vs. FM Modulator to Digital CD sound quality):
https://my350z.com/forum/audio-and-video/80720-sirius-pnp2-ipod-install-on-z-roadster.html
on
I can't wait to hook up this beeatch. I'll probably hook it up in the civic first since its snow season...hopefully the deck in it has aux in. It's a pioneer DEH 3500 i think, about a year old and "XM ready"....doh!
on
I rigged up the tuner in my civic since the Z isn't going to be driven much (being that its winter). Love it, love the selection of music too. I disassembled the suction cup device and just drilled the mount right into a flat portion of the dash. Works for me, wires tucked all over the place and I don't give a F.
I will be buying another car kit and having it professionally installed in the Z before spring.
