Stock Speaker Wires
hi i just recieved my jl xr650 components in the mail today and they didn't come with speaker wires
should i just use the stock speaker wires or should i buy them at the store they will be powered by an amp
thx for your help ^^
depends on wattage. low wattage= stock wires ok. high wattage = upgrade to lower guage. Don't buy speaker wire at car audio store. go online or buy wire, Bestbuy, or something equivalent. Remember that copper is copper.
I recommend 12-14 from amp to crossover, 16-14AWG to mids and 18 to tweets..that way if you end up upgrading or adding an amp in the future you will be all set. Oh, and the wattage specs of the speaker are not what determines the required wire size..it's the wattage of the signal you will be sending to them. If you are using stock Headunit and no aftermarket amp I would guess you are sending somewhere between 10-16watts per channel without too much distortioin. Stock wiring would be sufficient for that as thats what was used to handle the power in the first place. Now if you're gonna splice the head unit output into an amp or replace the headunit with aftermarket and/or add an amp..definitely go with the aforementioned sized wire upgrades.
this is my setup
clarion vrx935vd dvd head unit
JL xr650 component speaker
JL xr650 coaxial speaker
powered by JL 300/4 amp
JL 10w3v2 sub
powered by JL 250/1 amp
i have dynamatt, the nazar pods, and a 2 to 4 gauge jl amp wire kit
the coaxials come with speaker wire but the components didn't ...
with that setup what wires should i be using
and is there anything else i am missing?
the sub is going into the stock sub location with tons of dynamatt =D
thx for all your help audio gurus
JL 10w3v2 sub
k back from the dead
4ohms is the ratin im usin
so from my clarion head unit i will splice the speaker wires into the amp with regular size wires THEN from the amp to cross over and cross over to speakers i will use 16 gauge wires sounds right?
350Z_Al
Oct 29, 2020 07:44 PM
