4 gauge amplifier power wire routing
Old Jan 11, 2003 | 10:50 AM
DrewBert's Avatar
DrewBert
Default 4 gauge amplifier power wire routing
installing system and looking for a way into the cab from the battery if anyone has any pics or just explains how to do it would be sweet,
thanks
Old Jan 12, 2003 | 07:30 AM
SeattleInfo's Avatar
SeattleInfo
Remove the battery cover. Then remove the plastic mounting that the battery cover attaches to. Pick up the corner of the plastic hood trim behind the battery, and look just to the left and back behind the battery. A main wire cluster enters the cab at this location, with a rubber cover. Feed your wire through the rubber cover by poking a small hole in the rubber, and pull through. It'll take some time, but once finished allows for a really clean routing. Then go wherever you need to.
Stay on the passenger side if possible. All of the car signal wires and stuff are routed through the driver's side. If you have to go through to the back of the car, use the wire holders already in the passenger side. Good luck!
MAsSIVrOOM
Oct 20, 2023 10:50 AM
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
