rear speaker making "pop" noise
Old Jan 6, 2006 | 09:25 AM
tractng's Avatar
tractng
Default rear speaker making "pop" noise
Guys,
My rear driver side speaker is making a “pop/blow” noise once in a while. After it happens, the amp makes a clicking noise (to shut off and goes back on)
Any idea where I might start to troubleshot. A loose cable or bad speaker? It’s a pain to remove all the panels in the rear out.
Btw, the speaker is Diamond Audio and the amp is a Phoenix Gold.
Tony
Old Jan 6, 2006 | 10:48 AM
andyisphat2004's Avatar
andyisphat2004
what resistance is the speaker running at and what is the amp rated for. i had similar problem for running a jl amp at 1 ohm but its rated for 1.5 ohms
Old Jan 6, 2006 | 10:55 AM
Racerinlsl's Avatar
Racerinlsl
if you had a short in that speaker wire somewhere, that may happen. the pop is the short acting up, which overloads the amp and shuts it off. I had a similar incident in my home system. Turns out I had one little thread of the negative wire touching the positive wire and was overloading the amp every 2 minutes or so.
Old Jan 6, 2006 | 11:29 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Diamond Audio Coax?
For some unknown reason Nissan thought it would be smart to make the seat retract so far back that it has the ability to crush the speaker. I found that out the hard way as I noticed a buzzing noise in my driver's side speaker ... the seat back had snapped the tweeter out of the center of the midrange and it was hanging loose by the wires.
Old Apr 9, 2006 | 10:36 PM
ngcharleshk's Avatar
ngcharleshk
I also get the "pop" from the rear speaker, it was so all in a sudden and it sometimes scared my passengers as they dunno whats going on with it, it really sounded like someone really hit ur car from behind.
Old Apr 10, 2006 | 08:16 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
which PG amp?
your coaxial prob shorts out sometimes or your amp is shorting out at the terminals...check the connections
bcoffee20
Nov 19, 2015 06:39 PM
seagrasser
Oct 11, 2015 03:27 PM
cashmoney03
Sep 27, 2015 05:24 PM
Daniel_dh
Sep 7, 2015 12:56 PM
