Will this unit allow my ipod to work on my non-bose stereo?
http://enfigcarstereo.com/shopsite_s...NI_MLINK1.html
If this one wont, which ones will?
Thanks in advance!
Thanks in advance!
Originally Posted by Racerinlsl
vash, is the '04 non-bose satillite ready? If so, PAC AAI-NIS should work. Do a search on Yahoo and you'll find it at log jam electronics as well as some other outlets.
Originally Posted by Vash350Z
No, it isnt.
you can buy the Soundgate AUX-NISS adaptor. I'm not sure if the base head units have this connector.
vash - I did a search for stereo removal and found a few pics of people w/ base head units and they DID have that 12 pin adaptor, so you should be fine. I just ordered my AUX-NISS....expect an install this weekend. I'll take pics.
I have the soundgate aux-niss from http://www.logjamelectronics.com/soundauxniss.html and it works great! Easy install.
Vash, it's fairly straighforward. There's a how-to take the dash apart thread here w/ step by step pics. I don't have the link handy, but it's here. If I recall, a wiring diagram comes w/ the aux-niss. Very simple.
Second question - You're correct. This will give you a set of rca female inputs. You need to hook those to your ipod though. The best way is with a piece from blitzsafe called a universal ipod connector. It will hook into those rca inputs and connect to your ipod through the dock connector. This allows it to charge your ipod, as well as transmit the audio bypassing the ipod's equalization circuitry. The blitzsafe is available http://www.discountcarstereo.com/detail.aspx?ID=793 as well as numerous other places.
The cheaper, less quality route would be to just get a cable with rca male connectors on one end and a stero mini jack(headphone jack) on the other end. This won't give you quite the same sound quality from your ipod, and it also won't charge it. http://www.discountcarstereo.com/detail.aspx?ID=164
thanks for all the help!
so ill need one of these
AND
and ill be good to go?
AND
Im surprised that you need two pieces, no one makes a device that plugs into the radio and also into the ipod?
With these two pieces you can control the ipod through the factory stereo buttons?
If all this plug into the back of the stere where is everyone making the cable come out to plug into the ipod? pics?
