back up camera help
Old Jan 19, 2006 | 08:51 AM
SirZaLot's Avatar
SirZaLot
Default back up camera help
I am shopping for a keyhole type back up camera (the one you usually install them in the keyhole on the trunk).
Do you know if there will be any space behind the rear bumper for the camera?
Thanks guys.
Old Jan 19, 2006 | 06:47 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
If you're willing to cut medal there's a bit of hollow space between the steel and the plastic interior. This picture is of the existing hole that comes out behind the rear license plate.
Old Jan 20, 2006 | 09:31 AM
SirZaLot's Avatar
SirZaLot
paul, so I'll need to drill the metal bar and the foam?
Old Jan 20, 2006 | 11:35 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
You're going to end up drilling into something depending on where you want the camera to mount. The bumper is pretty deep and hollow in a bunch of places. If you're willing to have the camera mounted where there's enough hollow space then you'd only have to drill into the plastic of the bumper. Other areas are going to require lots more work drilling into the body, bumper, or brackets.
Old Jan 20, 2006 | 11:59 AM
SirZaLot's Avatar
SirZaLot
I'm thinking about mount it right in the certer of the rear bumper.
Old Jan 21, 2006 | 11:22 AM
rjpaterson's Avatar
rjpaterson
Z Enthusiast
You could mount like I did. Right through the rear license plate. The only drilling I had to do was the Plate and behind the plate through the bumper
Old Jan 21, 2006 | 01:27 PM
zcar03's Avatar
zcar03
I mounted mine right on the bumper but I have an aftermarket bumper so there was nice flat spot and I did it with the bumper off the car.
Old Jan 23, 2006 | 02:21 PM
SirZaLot's Avatar
SirZaLot
But do you have enough space behind the bumper, or you have to drill the metal bar and the foam?
Old Jan 25, 2006 | 03:51 AM
zcar03's Avatar
zcar03
I had enough space and didnt have to drill anything but the bumper. It is below the license plate.
Old Jan 25, 2006 | 12:43 PM
SirZaLot's Avatar
SirZaLot
How is a key hole camera with
420 TV lines, 110 Degree view, mirror image, water/shock proof
Is that good enough?
Old Jan 25, 2006 | 05:39 PM
NYC_G35C's Avatar
NYC_G35C
granted it's a G35, but i didn't do any drilling at all. my pioneer cam gets a great view, and the only thing i had to permanently modify was my license plate frame. the wire runs up thru the rear bumper and thru a factory rubber grommet into the trunk....
Old Jan 26, 2006 | 11:20 AM
pln2311's Avatar
pln2311
How much would it cost to install this on a Z?
Old Jan 26, 2006 | 06:27 PM
zcar03's Avatar
zcar03
It is a pretty straight forward install. I couldnt see anyone charging more than 75 bux including wiring. Thats what I would charge anyway.
Old Jan 27, 2006 | 01:02 AM
BlueDragonZ's Avatar
BlueDragonZ
Aside from the Pioneer one, what other camera are you guys using?
Old Jan 27, 2006 | 11:20 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Mine's the $37 e-bay special.
Old Jan 27, 2006 | 12:32 PM
cbrflyer919's Avatar
cbrflyer919
IT would cost considerably more if you want to run it through the factory nav system though. It requires a rather costly (around $300) adapter box. Best thing is to go ahead and get that aftermarket screen and run it into there, no adapterbox required
Old Jan 27, 2006 | 02:01 PM
rjpaterson's Avatar
rjpaterson
Z Enthusiast
Use aftermarket screen......
It cost me $600.00 just for the module to integrate with the OEM nav. It works great but was rather expensive...
Old Jan 27, 2006 | 05:02 PM
SirZaLot's Avatar
SirZaLot
Hi, anyway to show a pic of the camera on your rear bumper? Thx
Old Jan 28, 2006 | 05:49 PM
zcar03's Avatar
zcar03
Yes sorry. Ill post it tomorrow. I forgot my camera at the shop.
Old Feb 2, 2006 | 10:28 AM
SirZaLot's Avatar
SirZaLot
Did you have time to take some shots?
