Connect factory XM and Aux input
Old Jan 19, 2006 | 10:02 AM
cer2225's Avatar
cer2225
Default Connect factory XM and Aux input
I would like to know how I can add a factory XM kit as well as an Aux input to my Bose HU. I knowthe unit has SAT1 and SAT2 and with using an adapter I can plug into the SAT connection on the back of the unit (or on the prewired N-BUS connector in the trunk area) and have 2 AUX inputs, but what I would like is one OEM XM and one AUX.
Are there 2 harnesses' for SAT connections or just one? If there is just one, can I cut the wires and send just an aux audio signal to the SAT2 input using the PAC AAI-NIS and still have the OEM XM signal through SAT1?
Before everyone starts telling me to go after market, I like the stock look and am not quite as concerned abut the audio quality as others, as I probably enjoy the sound of the Z as much or more than any song.....
Thanks for your input.....
Old Jan 19, 2006 | 04:28 PM
cer2225's Avatar
cer2225
Someone has to know the answer to this.......
Old Jan 19, 2006 | 05:18 PM
Racerinlsl's Avatar
Racerinlsl
i don't think that would be possible. The AAI-NIS converts the sat. input on the back of the head unit into two sets of rca inputs. I just don't think it'd be possible to easily convert only one to an aux. input. It may be possible for someone w/ the proper wiring schematics and lots of time, but don't expect an easy solution.
Old Jan 19, 2006 | 05:21 PM
cer2225's Avatar
cer2225
Well if there are really two different sets of inputs SAT1 and SAT2, there should be 2 seperate audio channels going through the N-Bus as well as the other wires needed for display etc....
Old Jan 19, 2006 | 06:23 PM
Racerinlsl's Avatar
Racerinlsl
I would agree, but these things are always much easier theoretically than they end up really being. If I knew more about the back of the 04-05 head and more about the factory sat. units, I could help more. Sorry.
looking at this:
http://www.virtualo.net/products/pac/AAINIS.pdf
the aai-nis plugs into one 12 pin connector on the back of the head unit and that gets you TWO sets of inputs. So I guess you'd have to get a wiring diagram for that 12 pin connection in order to possibly make this work.
Old Feb 2, 2006 | 04:30 PM
ZBran's Avatar
ZBran
Just getting to this thread, and have received my much anticipatted pac-aai-nis2. This is a newly released product that has a male and female 12-pin connector, so you can plug your factory 12-pin xm into it. There is a switch on the pac for satellite radio equipped vehicles, so that you can continue using the factory satellite while still having two audio ins.
Depravity
Oct 1, 2015 04:49 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
