1000 spending limit (maybe more)
Old Feb 3, 2006 | 11:19 AM
Daytona350Texas's Avatar
Daytona350Texas
Default 1000 spending limit (maybe more)
Heres what im wanting, nothing TOO out there pretty stealth if I can really.
Im looking at the JL w7s 10s, and Im thinking about buying 2 of them.
Alright now what I never understand, amps/right boxes/wires.... etc, unload what i need to buy kinda like a shopping list and give prices to see if it exceeds my limit (most likely install myself w/an audio friend of mine)
Old Feb 3, 2006 | 11:37 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
The JL 10W7 has a pretty high Qts so you're going to need a huge 3.5 cu.ft. box to get to 0.707 Qtc. With a more normal sized 0.75 cu.ft. box you'll lose a bit of low end and have a bit of a hump (gain) at 80 Hz using those speakers.
Look for an amplifier around 300 watts, more if you want to crank those things up. Unless you're sold on those speakers I would look at the JL 10W6V2 which were about $300 each - the 7Ws were $400 each when I shopped for them last year. A Zenclosure is about the least expensive box out there at $99. Figure $330 for a JL 1/300 amplifier and another $100 for wire, distribution, fusing and possibly a cap.
JL 10W7 Speakers = $800
Zenclosure = $100
JL 1/300 Amplifier = $330
Wire etc = $100
$1330 ($1130 with the W6V2 speakers)
Old Feb 3, 2006 | 12:13 PM
CopperZ's Avatar
CopperZ
I have 2 10w7's with 1000.1 amp. love them.
here is what you need:
JL 1000.1 amp
Wire kit, if you have the $$$ get the JL one
Box for subs.
I have 1 10w7 that i can sell u, its new, and we make custom boxes box for 2 10w7s is $185+shipp. Pm me
Old Feb 3, 2006 | 01:15 PM
dream724Z's Avatar
dream724Z
The strut dual sub looks great... Unfortunately it does not meet JL's spec volume. The single under strut enclosure is ~0.65cf. So the net volume is lower, deducting for subs' displacement and the dual sub acoustic separation wall. The two powerful JL subs (W6/7) mentioned need a net volume of 1.25-2.5cf to reach their SPL potential. The W7 weight (30#) is 2x W6's and will require kludging spacers to fit the strut box. If you want the dually sound you need to match it with a bigger box, and more power. The optimal Z config is one W6.
Old Feb 3, 2006 | 04:09 PM
CopperZ's Avatar
CopperZ
Not true, here is mine:
Old Feb 3, 2006 | 04:33 PM
dream724Z's Avatar
dream724Z
That vinyl looks very nice. It appears your box extends past the strut? What is your enclosure's net displacement? I decided not to trade the convenient large duffle bag (A<>Strut) space for 1KW subs. But if one doesn't need storage the custom box options are impressive. Although your setup breaks Daytona350Texas' budget goals.
Old Feb 3, 2006 | 04:36 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Custom box?
Old Feb 3, 2006 | 05:19 PM
CopperZ's Avatar
CopperZ
Yea its custom 10w7 box that exends past the bar, and my friends at Bad Boy Bass make them, $189 for that box. But if he wants 2 10w7 a good amp box + wires you need more then 1G.
Old Feb 3, 2006 | 09:54 PM
Rasengan's Avatar
Rasengan
Zenclosure = $100
Wire etc = $100
i just bought 2 JL 10w6v2's and 2 JL 500/1 amps in a Zenclosure dual 10" with the amp rack (which allots for twin 0.67 chambers)...you think i won't need the 2nd amp and just run both subs on the single 500/1?
Old Feb 3, 2006 | 10:57 PM
dream724Z's Avatar
dream724Z
The JL500.1 amps are stable to 1.5ohm (wire the 2 W6 for 4ohms). Listen to them first with just one amp. It should sound incredible in the Z. Enjoy!
Workshop12
Mar 23, 2020 01:45 PM
nanotech
Oct 2, 2015 05:02 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
