Wiring Color code Guide for 350Z
Old Apr 15, 2012 | 08:49 AM
  #41
sportbiketed's Avatar
sportbiketed
http://www.the12volt.com/installbay/...s.asp~TID~8149
Old Feb 10, 2013 | 09:05 PM
  #42
Sonic1's Avatar
Sonic1
Is the headlights the same as parking lights?
Parking Lights+ red/blue + driver kick panel
https://my350z.com/forum/autocross-r...ht-switch.html
Old Feb 11, 2013 | 08:34 AM
  #43
sportbiketed
No.
Old Nov 3, 2013 | 11:25 AM
  #44
David350k's Avatar
David350k
have one connector from new HU and 2 connectors from inside the car and new connector and one old one has a black wire for ground but the other old connector has a black and white stripe on it. Is that tobe connected with the solid blacks or where is that to be connected with??
Old Nov 22, 2013 | 01:42 PM
  #45
beezbo's Avatar
beezbo
For those out there trying to find a 12v power source for aftermarket gauges (navigation/cubby area) and use the radio/stereo for power, I believe that the yellow wire is a constant 12v source and the light green wire is a switched 12v source. Correct me if I'm wrong?
Old Dec 29, 2013 | 07:45 AM
  #46
Glynne62's Avatar
Glynne62
Thinking of buyin one of these remote alarms that also remote start your car for u. On my 03 350z fair lady..Has anyone here fitted one before
Old Dec 29, 2013 | 07:47 PM
  #47
sportbiketed
Yes
Old Dec 29, 2013 | 09:39 PM
  #48
l2iceman's Avatar
l2iceman
Yellow is constant. Not sure a bout green but from what I remember, it was the red wire which is tied to ignition. This was the one I tapped into when hardwiring my gps.
Old May 5, 2014 | 01:51 PM
  #49
ryanmackk's Avatar
ryanmackk
The attachment is an organized version for 2006:
Old May 26, 2016 | 02:56 PM
  #50
NissanTracker's Avatar
NissanTracker
Not to bring an old thread back... i'm trying to install one of those iSimple bluetooth inline FM modulators and I can confirm that YELLOW is a constanct 12V source and the LIGHT GREEN (TEAL is my eyes) is a switched 12V source.
The LIGHT GREEN/TEAL is what I'm using to switch the modulator on
Old Jun 2, 2018 | 03:43 PM
  #51
Leerob's Avatar
Leerob
Default I need help!
could someone please post a picture of the wiring harness for the radio that has the colors of wires for which spot they go in the plug? 2004 350z
Old Jun 2, 2018 | 03:46 PM
  #52
Leerob's Avatar
Leerob
Can anyone post a picture of the main radio harness with the power supply wire for a 2004 350z. My clip broke and all the pins receded out and a need to picture to put them back in the correct spot. Do diagram I’ve seen actually works
Old Mar 27, 2020 | 06:05 PM
  #53
HessExpress's Avatar
HessExpress
This exact problem just happened to me on my 04 z, I've tried countless times to put the wires back where they need to be on the diagrams but my head unit still hasn't showed any signs of life. It doesn't help that whoever the last owner was butchered the wiring and created a rat's nest that is nearly impossible to track. I have a light green, green/ white, thick yellow, black/white, red/white, red/ yellow, red/blue, blue/red, and yellow/red wire. Just wondering if anyone knows which pin they go into or if these are even oem colors. Also it is not a nose system, they can be different. I've read the forums and they have been helpful in identifying what each wire is but I haven't seen anything on where they go. Cant confirm what I have is right, nothing turns on but I'll add attachments to show what I have done.
Any help would be appreciated :P
Old Sep 17, 2020 | 12:29 AM
  #54
Jean Lubbe's Avatar
Jean Lubbe
Okey so Ive looked through every forum and still don't understand the color coding of my speaker wires. They don't match the diagrams and don't match what people are saying.
​​​​​​I want to connect an amp to my stock headunit. I have an Aerpro line out converter because there are no RCA in/outputs so I have to cut and connect the speaker wires to the converter. All I need it the speaker wire colours
please.
Old Feb 25, 2021 | 03:43 AM
  #55
Grant Gobin's Avatar
Grant Gobin
Default i need help with my 2005
help!
can someone post a picture of there harness I have no idea where there 6 wires go in the harness there would fit
Old May 14, 2022 | 05:14 PM
  #56
inabj2's Avatar
inabj2
There!
im posting this, so the next poor soul that accidentally depins their plug like I did. Doesn’t have to spend the next 4 hours searching in vain in the Internet, in the fsm, in images in threads from 20 years ago. Finally piecing together, enough info to put it back together from a picture in 2006 taken by a god damn potato, and a Bose diagram from a 2000 Nissan Maxima which was 50 percent WRONG. To finally get the correct solution which is the picture I posted in this post. This is what it’s supposed to look like if you have a 2003 Nissan 350z track. Jfc.
Old Jun 27, 2022 | 09:51 AM
  #57
Lean350Z's Avatar
Lean350Z
Originally Posted by inabj2
There!
I created an account especially for this.
I have been searching for days and days on end, i am completely lost. You posted the picture of that connector which exactly matches mine, that connector is part of 3 white ones. I have a 2003 too and i really need a picture of the biggest connector from those 3, i cant find it anywhere and im completely lost. Could you please, out of the kindness of your heart take a picture of the biggest connector from those 3? I would be absolutely ecstatic if you could do that so i can get my radio working again!
Edit: i honestly am willing to paypal you something for the trouble, thats how bad i want it lol
Old Apr 12, 2023 | 11:35 AM
  #58
bisha's Avatar
bisha
that was a great post i don't know how i miss it thanks for sharing.
Old Apr 12, 2023 | 11:47 AM
  #59
Lean350Z's Avatar
Lean350Z
Edit 2: i figured it out with all of the above and the fsm for the 2003 and 2004 models.
Old Apr 17, 2023 | 11:09 AM
  #60
The Bull's Avatar
The Bull
I would suggest folks at least do their due diligence at labeling connectors as they take these pictures and compare them to what the FSM has it listed under. Many times with Bose iterations these colors might be different than others.
nething2blind
Apr 28, 2009 04:34 PM
asianracerchick
Dec 3, 2007 06:49 PM
Rob Hines
Jun 29, 2005 06:51 PM
ZZtopp
Aug 5, 2004 01:26 PM
