What Amp To Power Two (2) Type-R Subs?
Other than JL please
I want to power 2 Type-R,s that are 10 inches =P
I dont know if I should get the 4 or 2 ohm version... all dependsn on the amp people suggest.... they are rated at 500W each... so do i technically need 1k watts? =(
kenwood excelon mono
Brand New KENWOOD EXCELON KAC-X812D MONO AMPLIFIER
1600 Watts Peak Power
400 Watts x 1(20-200hz, 0.5% THD) @ 4 Ohms
800 Watts x 1(100hz, 0.5% THD) @ 2 Ohms
1300 Watts x 1(100hz, 1.0% THD) @ 1 Ohm
High Performance Mono Power Amplifier
Class D Amplifier Circuit
A.M.S. (Amplifier Management System) -Built in Parametric EQ Control -AMP Information Display (Voltage,Current, Temperature, Cooling Fan Speed)
Built-in Variable Low-pass Filter
Built-in Infrasonic Filter
1� Load Capability
Gold Plated Input/Output Terminals
Line Output Terminals (RCA) for Extension
2-Speed Cooling Fan
Detachable Aluminum Dress Plate
1� Load Capability
2-Speed Cooling Fan
Tochigi_236
Sep 27, 2015 03:40 PM
