Need Help: Eclipse Ipod Adapter For Avn5435
Old May 2, 2006 | 07:51 PM
RANDY350Z's Avatar
RANDY350Z
Default Need Help: Eclipse Ipod Adapter For Avn5435
I just got an i-pod 60g for my birthday and I purchased the ipc-106 adapter from Eclipse (they said it was compatible with the 5435). anyway, instructions aren't clear---I connected the ipc-106 to the sirius tuner and didnot get any results. I am thinking I have to connect te ipc-106 directly to the 5435 and then connect Sirius to lan1 on te IPC-106. I will be getting a cd changer this week so i tink it goes into lan 2.
Is this right? I emailed Eclipse, sometimes it takes awhile to get back.
Also, I don't have windows XP, does anyone have a spare disc that I can use to download?
Old May 19, 2006 | 04:12 PM
Cambelsoop's Avatar
Cambelsoop
? i was curious did u ever figure this out?
Old May 20, 2006 | 10:02 AM
RANDY350Z's Avatar
RANDY350Z
Yes I did! Eclipse is awesome for support--you get right thru. Any way, I ran it directly to the 5435, ten ran the sirius tuner to it--set the switces to A/A and boom--it works. You can connect a on/on toggle switch to run the ipod and sirius so I will attempt it this week. I wanted to make sure the ipod worked before I did all this!
Old May 25, 2006 | 02:09 PM
Cambelsoop's Avatar
Cambelsoop
u plugged ur sirius adapter into ur ipod unit? and ur ipod unit into the sirius adapter on the back of the HU?
how do u activate the ipod adapter in the menu screen?
Old May 25, 2006 | 02:36 PM
Cambelsoop's Avatar
Cambelsoop
i just called eclipse , and the tech guy said it would wrk with the 5435 but it would have to go in wither the SAT , or the cd changer plug i am curious to c what it would look like on the screen in either of these plugs?
either way i just ordered 1 from an ebay store, for like$105 NIB
so we will c
thanks randy
Old May 25, 2006 | 07:58 PM
excid182's Avatar
excid182
i just did the exact same thing as well...called eclipse and they helped me out.
you want to plug your ipod box directly to the deck w/ the cable plugged into LAN2 and then you want to run the other cable from LAN1 to the OUTPUT of the Sirius box. Then you want to switch those 2 tiny switches to AA and it should work for you.
m_0g
Jun 3, 2021 10:05 AM
Dsowe
Feb 17, 2021 10:38 AM
jlb
Oct 15, 2017 05:10 AM
DarkCreep
Oct 17, 2015 11:50 PM
