Bose 2005 Vs. Bose 2006
Old May 26, 2006 | 12:55 PM
  #41
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
assuming the 05 Bose head unit has the auxilary port, yes you can connect any peripheral device to the head unit
Old May 28, 2006 | 06:56 PM
  #42
slaponte's Avatar
slaponte
Originally Posted by WickedKE
hummm so you are saying you can connect a IPOD in the 05 Bose???
Yes. You use one of the rear ports with a PAC NIS something and that gives you aux inputs. I have it installed on my 2003 :
- switched the 03 Bose for an 05. The buttons are laveled different
- you get the PAC NIS... I have to look it up
- Is a direct plug in.
Old May 28, 2006 | 09:52 PM
  #43
3hree5ive0ero
Retired Admin
^ i wanna learn more about that auxilary port thing.. any more info? and would you mind looking up the exact name, slaponte?
Old May 29, 2006 | 03:08 AM
  #44
Derek's Avatar
Derek
Pac Aai-nis2
Old May 29, 2006 | 12:39 PM
  #45
3hree5ive0ero
Retired Admin
thanks
Old May 30, 2006 | 07:31 AM
  #46
slaponte's Avatar
slaponte
Ok, more info.
A) The radio itself : the "older" Bose can be noticed becaause the top buttons read "CD, Tape and AM/FM". The later model (2004.5 forward) the AM/FM button has been labeled RADIO. On the back the plugs are the same. The main difference is that the later model has the "intelligence" inside to cycle to aux inputs off the external sat unit plug.
Here is the 2004.5 forward Bose. Notice also it is BLACK, while my original was grey. I think it looks fine on the console, but opinions might differ.
The rear (to my surprise) looks the same on both. The plugs are there, they are just not used...
B) The PAC AAI-NISS2 takes one of those ports and converts them into a couple of aux inputs (you know, left and right wires), that you can use to hook in your iPod or any other device with L/R aux output.
http://www.logjamelectronics.com/pacaainis.html
Thats one link but you can google or shop around. Note how they state that it fits the 350Z 2004 - 2005.
Hook up is plug and play. You have to take out the center console (there are some writeups around), remove the current BOSE (03), install the new BOSE, hook up the PAC unit, run your RCA wires to a convenient place, and put everything back together. It is fairly simple.
To operate, when the radio is on, as you press the "Radio" button it will cycle through AM, FM1, FM2, SRC1 (= aux 1), SRC 2 (= aux 2), back to AM. I hook up the iPod, cycle to SRC1 and go.
This DOES NOT give you iPod control from the radio. All you have is input of the RCA lines, no output to the iPod of anything. If you want iPod control you need other (more expensive) solutions.
Hope that helps.
Old May 30, 2006 | 03:32 PM
  #47
3hree5ive0ero
Retired Admin
slaponte - thank you very much for that write up..so you're saying that the 03's cannot cycle to src1/2 therefore we must have the 2004+ bose?
Old May 30, 2006 | 05:31 PM
  #48
slaponte's Avatar
slaponte
correct. Too dumb.(the radio I mean).
But don't get a 2006 because they have rounded edges and won't fit the console. You need a 2004.5 to a late 2005. Just check the "radio" button and the edges.
Old May 30, 2006 | 06:04 PM
  #49
xStriderx's Avatar
xStriderx
I have a totally random but related question. Sorry for Hijacking.
I was wondering If I could buy the complete whole center console(which I could really cheap) and then go on to purchase the new 06 Mp3 capable Head Unit. I know i might have to buy a new Emergency button and etc. to complete the console but again i'm willing to spend the cash. Basically does anyone know if its a direct bolt on?
Old May 31, 2006 | 02:02 PM
  #50
slaponte's Avatar
slaponte
I haven't read if it is a direct bolt on or not. I mean, if you get the console etc of course it would bolt on, I imagine you are asking about the wiring. I would be surprised if it isn't. The MP3 features etc are in the HU anyway. The connectors in the back are to the amps, power, etc. Why would those change?!
But, I guess, somebody has to try.
Old Jun 1, 2006 | 09:36 PM
  #51
WickedKE's Avatar
WickedKE
ok stupid question...( i dont know **** about Ipods)....when the RCA's come out of the "PAC" after you connect to the Bose, you connect those RCA to the Ipod correct? =)
Old Jun 2, 2006 | 04:37 AM
  #52
Derek's Avatar
Derek
^^ correct
You need an RCA to 1/8" stereo (2 rings) adapter which you can get from radio shack. Or, buy an ipod controller like the Harman Kardon Drive+Play.
Old Jun 2, 2006 | 07:48 AM
  #53
slaponte's Avatar
slaponte
I use the first one, RRCA to 1/8"stereo cable. Goes on the "headset" plug on the iPod and gives you two RCA connectors. This gets you music, but wont charge the iPod.
There is a better iPod only cable that gives you the RCAs and a plug to the lighter so you can listen and charge. Is more $$$
Old Jun 3, 2006 | 10:22 AM
  #54
WickedKE's Avatar
WickedKE
Does anyone in Phoenix know how to do this? I can pay them..I'll buy the parts
Old Jun 3, 2006 | 05:11 PM
  #55
slaponte's Avatar
slaponte
I can help you in Miami... is a short drive.
Old Jun 4, 2006 | 03:49 PM
  #56
WickedKE's Avatar
WickedKE
Or does anyone in Phoenix know where I can go to get this done and get ripped off or something......What kind of setup will enable me to control the IPOD?
Old Nov 29, 2012 | 12:22 PM
  #57
doorpro's Avatar
doorpro
Default LOL.... Focus
Anyway, can you not remove the plastic face plate on the 2006 model Bose HU and replace it with the face plate from the 2005 so that the fit will be perfect? I am removing the Bose HU from my wifes 2006 convertible and it looks like the face plate is removable. Just a thought!
Old Nov 29, 2012 | 02:53 PM
  #58
skeetzee's Avatar
skeetzee
Holy thread resurrection batman
Old Nov 29, 2012 | 03:14 PM
  #59
doorpro's Avatar
doorpro
Yup, didn't check the dates, was just looking around for an answer to my problem and felt the need to say something to someone, anyone...
3vilbunny
Jul 18, 2017 05:10 PM
kyin
Oct 15, 2015 05:54 AM
nissan1310
Oct 12, 2015 08:54 AM
