Viper alarm install.
Old Jun 26, 2006 | 07:43 AM
Z_rican's Avatar
Z_rican
Default Viper alarm install.
What's up guys. Here is the deal I have a Viper alarm that I want installed in my Z. I have a 6 speed. Can anybody do the install for me? I cant find a shop that will install the remote start for me. I want to do the install in about a month and a half. I am willing to pay and give beer. I live in NOVA. Can anyone help me out?
Thanks in advance.
Old Jun 26, 2006 | 07:48 AM
wilric44's Avatar
wilric44
remote wont work with a manual. i have it on my 5AT
Old Jun 26, 2006 | 07:51 AM
Ichigo's Avatar
Ichigo
Default Liability
Shops wont install a remote start on a manual trasmission car. Too much liability involved. You have to bypass a safety feature, having to have the clutch in before the car starts. Im not saying it CANT be done but a professional shop most likely tell you it CANT be done because they dont want to stand there and argue with you about doing it. You get hurt = They get sued.
There is one company out there that makes a remote start that works with a manual transmission though .. name escapes me compu.. something. Ill have to look it up if your interested.
Got it, Compustar sells remote starts that are Manual transmission capable!
This is the only remote start system that is currently manual transmission capable, that I know of.
http://www.compustar.com/remote_start.htm
Old Jun 26, 2006 | 07:55 AM
Z_rican's Avatar
Z_rican
Sure if you dont mind.
Thanks.
Old Jun 26, 2006 | 08:20 AM
DeeZ's Avatar
DeeZ
compustar i think makes one
Old Jun 26, 2006 | 08:24 AM
philude's Avatar
philude
i have a friend that lives in annandale and does this in his spare time. he did a great job for me. if you want his info, i'll PM it to you.
Old Jun 26, 2006 | 08:55 AM
KPierson's Avatar
KPierson
You can safely install a remote start on the VQ35 because it includes an OEM neutral safety switch. This switch signal can be referenced to prevent the car from starting if it is in ANY gear.
Also, the clutch bypass should only engage when the RS is triggered, and should reamin in place for normal starting of the car.
The DEI alarm has a NSS wire, its a black/white wire that 99% of the time is either wired through a toggle switch or directly to ground. Hook this wire to the OEM NSS wire at the ECU, you can wire it through the switch still, too, if you want to be able to manually defeat the remote start.
One word of caution, the OEM NSS switch (technically referred to as a PNP switch - Park/Neutral Position) is a mechanical switch that is located INSIDE the transmission. As it is mechanical it CAN fail, and should be tested out at least monthly for proper operation.
This way of installing a remote start is AS safe as installing the system on an auto tranny, as long as the OEM PNP switch is working as designed.
For reference, Nissan uses this signal to prevent 'no load revving' by enabling a 2nd, lower, rev limiter when the car is in park (auto) or N (6mt).
Old Jun 26, 2006 | 09:16 AM
Z_rican's Avatar
Z_rican
Thanks for the link.
Old Jun 26, 2006 | 09:17 AM
Z_rican's Avatar
Z_rican
Yeah man, can you please PM me his info
James1990
Dec 16, 2015 08:57 PM
kyin
Oct 15, 2015 05:54 AM
kyin
Sep 29, 2015 06:57 AM
ZThang
Jun 24, 2003 08:00 PM
ZThang
Jan 11, 2003 10:22 AM
