CarPC
Old Jun 28, 2006 | 11:55 PM
Bam-0's Avatar
Bam-0
Default CarPC
I really want to get one instead of using a Nav/DVD system on the cubbie.
Is there anyone out there or anyplace that will sell them with progams allreadyy running that tell you info. about the car and stuff like that?
i mean i really dont know enough yet to build a pc by my own.
Old Jun 29, 2006 | 09:55 AM
maturola's Avatar
maturola
Default There are some out there!
I seen some "Car PCs" but i don't think they really worth it. You can get a old Thinkpad on ebay for a couple of humdres, wire the output to your HU and Run Linux on it (Windows will do fine however you have to deal with the Licenses fees).
There are tones of USB GPS and free software to use with it
This is what i installed on my old Mustang, I will install a PC on my Z as well, but i want to have the Sound System ready first.
http://www.mightygps.com/linuxgps.htm
http://gpsdrive.kraftvoll.at/
good luck!
Old Jun 29, 2006 | 10:02 AM
Alang's Avatar
Alang
Unfortunatly for you, Car PCs are really do it yourself items.
I was in the same boat as you when I started. If you are willing to spend time researching, it is very doable, just be patient.
I had never built a PC before, but with a little time on the net, I bought the components for a mini-itx form factor machine, put it together, and it actually works!
The install in the car is easy enough. There are several pages that have screen installs in the nav cubby, everything else is easy.
For software, go to mp3car.com. Tons of frontend info and freeware/shareware app info. Again, take your time and do your research and you can do it. Patience is key here. If you are hot to have something right away, your probably going to be dissapointed. But if you are willing to build a basic system and then customize and expand it slowly, you are only limited by your own imagination.
Good luck.
Old Jun 29, 2006 | 10:08 AM
BhashaZ's Avatar
BhashaZ
www.streetdeck.com
Kind of pricey, but you don't have to do anything yourself, minus actually installing it in your car.
Nuked
Audio Video
Mar 2, 2013 03:49 PM
TheStonedOne
Dec 22, 2012 05:47 PM
smalmo1
Audio Video
Feb 1, 2012 04:21 PM
bay350z
Dec 27, 2006 11:04 AM
exan
May 9, 2006 09:01 AM
