please help...
Old Jul 6, 2006 | 06:40 AM
behjjeh's Avatar
behjjeh
Vendor - Former Vendor
Default please help...
im going to install amp and subs in OEM HU this sat.. need little help..
i just grap the line out put conv, and i dont know where this wires need to tap in to.. do i need to tap in to rear speaker wires? or OEM subs wires.. and should i tap it in to near the HU or it doesnt matter... and what colors are they? speaker wires.. please help!!!
thanks!
Old Jul 6, 2006 | 08:10 AM
behjjeh's Avatar
behjjeh
anybody?!
Old Jul 6, 2006 | 08:18 AM
bmac03z's Avatar
bmac03z
You will need two lineout converters because the front and rear speakers are highpass filteres and the sub is low pass. All you do is t-tap the factory speaker wires. If you want to maintain fade front to rear you'll need three converters
Old Jul 6, 2006 | 08:25 AM
Ichigo's Avatar
Ichigo
You may want to consider taking it to a stereo shop.. installing on your Z is not the best time to be learning automotive wiring 101. If thats not an option, make sure you have all of the color codes for the wires in hand before you start. If the Amp you want to connect already has line level inputs you dont need a converter for that amp.
An amp and sub install shouldn't run you more than $75.00-$100.00, unless you want something custom done.
Old Jul 6, 2006 | 08:36 AM
behjjeh's Avatar
behjjeh
can i just tap in to rear speaker and do it?
StateNuke08
Oct 31, 2015 05:01 AM
rmesola
Feb 6, 2006 08:54 PM
roberto350z
Oct 5, 2005 08:02 PM
spdu4ia
Nitrous Oxide
Feb 24, 2005 02:37 PM
