help please..... short circuit
Old Jul 6, 2006 | 11:03 AM
ss350's Avatar
ss350
Default help please..... short circuit
Hey guys,
I was trying to fix my back-up camera. While I was checking the voltage on the power wires to the camera, I accidentally touched the two wires. My key was in the ignition at the "accessory" setting. When the wires touched, radio shut off and a bunch a lights turned on on the dash. Now when I put the key back to the accessory setting, my radio won't turn on and the light on the dash are still on.
What should i do?
BTW I can't try to start my car b/c I'm waiting on a part for my supercharger. Right now I have the battery disconnected hoping the ECU will reset and magically fix itself....lol.... =(
Old Jul 6, 2006 | 12:21 PM
Realrammstein's Avatar
Realrammstein
I do hope your luck is better than mine was. I did that with my 2nd to last install. I blew everything from the radio back to the amp. A very expensive lesson to learn to always disconnect the battery.
bmac03z's Avatar
bmac03z
ummmm....Fuse
Old Jul 6, 2006 | 12:42 PM
Realrammstein
For mine, it actually damaged the entire interior fuse box. I had to find a totalled car to replace that (last car).
Old Jul 6, 2006 | 12:45 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
check your fuse boxes
Old Jul 6, 2006 | 01:47 PM
Eazzy's Avatar
Eazzy
Keep in mind there are 3 boxes
Old Jul 6, 2006 | 04:09 PM
3hree5ive0ero
Retired Admin
Uh.. isn't there only 2? Where's the 3rd one?
Old Jul 6, 2006 | 06:30 PM
ss350's Avatar
ss350
dammmmm..... so it doesn't look good huh
Old Jul 6, 2006 | 08:04 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Might cost you a $0.25 fuse if you're lucky. Depends on where you tapped in for power. Hopefully you tapped in downstream of a fuse which has now popped. If you tapped on a direct connection to the battery you may have blown a fuseable link but normally you would have started a fire with tiny wires like those on a backup camera.
Old Jul 6, 2006 | 11:07 PM
evobunny's Avatar
evobunny
yes get a tester and test all your fuse first. pretty sure you blew some.
Old Jul 7, 2006 | 02:50 PM
ss350's Avatar
ss350
fixed it. It was just a fuse in the interior fuse box... thanx guys
Old Dec 14, 2008 | 04:09 PM
burner's Avatar
burner
Hey guys,
What should i do?
Bringing back an old thread...This happened to me today and I checked every fuse in the car to no avail. What should I try next?
Old Dec 14, 2008 | 06:45 PM
KPierson's Avatar
KPierson
What did you use to check the fuses? Sometimes a visual check will miss hairline breaks in the fuse element. Always use an ohm meter to check fuses.
Old Dec 16, 2008 | 05:37 AM
burner's Avatar
burner
I took your advice and checked every single fuse in the car for continuity, and found a fuse that looked perfectly fine, but was blown. Turns out it was the power mirror fuse (drivers kick panel). Who would have thought that a power mirror fuse would cause half of the car to shut down?
Depravity
Oct 1, 2015 04:49 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
ddegrande21
Sep 6, 2015 11:15 AM
