Specs for stock amp and sub please
Old Aug 9, 2006 | 08:31 PM
Mewantbfp's Avatar
Mewantbfp
Default Specs for stock amp and sub please
Could someone please give me all the specs for the stock amp and sub on the bose system im replacing my stock sub with a 400rms 800 max 10" audiobahn sub. And i need this info by tomorrow (im doing the sub install then) also does anybody know which wire is the positive and which is the negative out of the blue and yellow ones that plug into the sub. (also if you have done a similiar set up i would greatly appreciate and knowledge you can offer do you think the stock amp will be fine to power the sub? And is there anyway to take out all that rattling im hearing in the back?
Old Aug 9, 2006 | 08:35 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
You couldn't find a smaller amplifier to drive your amplifier if you looking night and day for a month.
The little tiny thing to the right of the real amplifier is the bose one. No really.
Rattles?
The best thing to do is to blow out all the bose stuff - keep the antenna amplifier and mount if you want but I changed out everything else from the headend to the antenna and haven't looked back.
Old Aug 9, 2006 | 09:23 PM
Mewantbfp's Avatar
Mewantbfp
damn thats small i hope it will at least slightly power the sub enough until i can get an amp because if it doesnt ill have to shell out some extra cash for one right then ( no big deal my roomate owns a car audio business so im getting everthing discounted) but still. Thanks alot for the comparison I will probably end up switiching out everythng in time. Do you happen to know which wire is the positive and negative out the blue and yellow wires that plug into the stock sub?
Old Aug 10, 2006 | 10:49 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Blue is positive (+)
Yellow is negative (-)
Old Aug 10, 2006 | 01:55 PM
Mewantbfp's Avatar
Mewantbfp
thanks for all your help. Do you know how many watts the stock amp could power at 1 ohm, 2 ohm, 3 ohm etc?
Old Aug 10, 2006 | 03:38 PM
Mewantbfp's Avatar
Mewantbfp
put the sub in and the stock amp powered it fine it sounds much better then the stock sub but not nearly as good as it can sound so in a few weeks ill be getting an aftermarket amp. I was wondering though if you could tell me where the stock amp was located any help would be great thanks. Also is the stock amp able to power at 1 ohms or will i blow the amp if i try that i have it set for 2 ohms right now.
Old Aug 13, 2006 | 06:36 AM
deviantZ's Avatar
deviantZ
Bump. I'd like to find this info too.
Old Aug 13, 2006 | 10:13 AM
maturola's Avatar
maturola
Default I need the remote turn on signal
I would like to know if anyone know if I could get the remote turn on signal form the stock amp.
Old Sep 25, 2006 | 01:56 PM
SSJVegita's Avatar
SSJVegita
anyone know where the stock bose amp is located??? need the info for my project..........
Old Sep 25, 2006 | 05:04 PM
topgear's Avatar
topgear
It's behind the stock subwoofer. Need to take out the subwoofer to get to it.
I replaced the 2 Bose amps with this one. All speakers have been replaced too.
Old Sep 25, 2006 | 08:36 PM
dbpoet's Avatar
dbpoet
The boze sub amp is behind the sub. The other amp is in the back to the left behind the black foam.
kyin
Oct 15, 2015 05:54 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
