How Do I Fix the Outside Temperature Guage
Old Aug 10, 2006 | 04:36 PM
Fyxtion's Avatar
Fyxtion
Question How Do I Fix the Outside Temperature Guage
I had Best Buy install a ipod interface for me today, when they were done the outside temperature just reads as 4 dash's and the ice light is on They didn't know how to fix it and basically said "not my problem". Does anyone know what's wrong, is there a simple reset I need to do, please help!
Fyxtion
Old Aug 10, 2006 | 05:00 PM
Nforce1's Avatar
Nforce1
Disc. the battery??
Old Aug 11, 2006 | 08:07 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
From the service manual (driver information system):
With ignition switch ON position, trip computer displays outside air temperature according to signal of outside
air temperature from unified meter and A/C amp. Unified meter and A/C amp. receives these signals from outside
air temperature sensor.
The outside air temperature is displayed while the ignition switch is in the ON position.
Signal is supplied
 through ambient sensor terminal 1
 to unified meter and A/C amp. terminal 39.
 through unified meter and A/C amp. terminal 10
 to triple meter terminal 5.
Indication range is between -30 and 55°C (-22 and 131°F). When outside air temperature is less than -30°C (-
22°F) or more than 55°C (131°F), display shows “--”. When outside temperature is less than 3°C (37°F) continuously, display will “ICY” indicator illuminate as warning. In this case, the display will change to the outside air temperature mode even though the display is showing a different mode. The “ICY” indicator will continue illuminate as long as the temperature remains below 4°C (39°F).
The ambient sensor (temp sensor) plugs into the Unified Meter and A/C amplifier so it is likely the fault of the installation. The AC amp is a white box located just forward of the shifter and under the radio area. Check to see if other things aren't working as that little white "black" box controls some otherthings - like the heating and cooling, fuel gauges, speed pulse ....
Old Aug 11, 2006 | 09:15 AM
VandyZ's Avatar
VandyZ
I bet they tried to use a power or ground off the A/C amp pictured above. I did the same thing when I installed my XM . . . I dont remember what messed up but basically the only thing you should really tap off the A/C amp is the speed signal for a NAV system. Tell your installers that the A/C amp is not a great place to tap.
Old Aug 12, 2006 | 09:42 AM
Mad Max's Avatar
Mad Max
If I may, also concerning the trip info gauge... is it possible to change the readings from MPH & Farenheit to KPH & Celsius??
Thanks.
Old Aug 12, 2006 | 10:35 PM
Fyxtion's Avatar
Fyxtion
Talking
Disconnecting the battery for a few hours worked - I did it, we went out to dinner, when we came home I reconnected it and it works fine - thanks!
Fyxtion
Old Aug 13, 2006 | 07:43 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Thanks.
Nice car
I looked thru the driver's information system service manual and don't see that it's possible. Is there a local dealer there that could possibly help you?
Old Aug 13, 2006 | 09:30 AM
Mad Max's Avatar
Mad Max
Originally Posted by Paul350Z
Nice car
Thanks, I saw in the manual that the gauge shows either MPH or KPH so I was hoping that a simple combination of button pushing would toggle between the two... oh well
If I figure it out Ill let you know
BTW you can update your sig, one of the 259 sold in the US is over here now
Old Apr 17, 2007 | 02:46 PM
cckleung's Avatar
cckleung
My car had the same problem and disconnecting the battery for a few minutes worked for me. Thank you.
Fyxtion
Uriyo_
Sep 8, 2021 08:46 AM
Cashwin
Oct 1, 2015 06:36 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
