2006 Z, Avic-Z1, JL AMPS, 2 x 10W6v2 - Install Done - Issues & Comments (56K warning)
Old Aug 16, 2006 | 11:02 AM
Hybrid90's Avatar
Hybrid90
With the components mounted in the factory speaker locations, do you hear any rattles coming from the door? Are the tweeters separate or built into the speakers? If they are separate, did you mount it in the factory location next to the window?
Old Aug 16, 2006 | 11:08 AM
maturola's Avatar
maturola
Default Factory location
Speaker and tweeters are in factory location, The Jl XR650-CSi have separate the tweeters & woofer. I dynamated the whole door, even put a few inside the door behind the glass. no rattle for me.
I also dynamated the rear panel.
I get some rattle fomr the trunk (i didn't have anough dynamat there, but I will get some) when the subs crack up.
Old Aug 17, 2006 | 07:41 AM
bdmpastx's Avatar
bdmpastx
Maturola,
Did you have to drill the brackets for the avic z1 to open? I read where someone mounting another DD setup had to drill holes 3/8" back. I mounted mine in the stock holes and the door was sticking. So I drilled some more holes and tried it again...still sticking. Then I tried another set of holes and I finally got it to work. It was a pain in the *** and I ordered another set of brackets to redo it cause I am not happy with it and I have no room to get another set of holes in there.
Old Aug 17, 2006 | 08:21 AM
maturola's Avatar
maturola
Default Dindn't have to drill
Originally Posted by bdmpastx
Maturola,
Wow.. Weird, mine fit perferctly in the stock holes. i didn't drill anythig I unsrew the stock boss radio, screw the avic and done.
Old Aug 17, 2006 | 11:27 AM
Anu2g's Avatar
Anu2g
with my alpine screwed into the factory holes, it sticks out like a centimeter. i actually like how it looks, but if i want to flush it, i'd have to drill holes.
Old Jul 30, 2008 | 02:09 PM
HareluyaZ's Avatar
HareluyaZ
I just got a Z1, i wanted to install it on my 2007 350z. But i know nothing about installation besides looking at this picture tutorial at *********.com. But is 2006 and older model only.
So does anyone here know how to take apart the center console for a 2007 350z? Any suggestions will help, thanks in advance
Old Jul 30, 2008 | 03:05 PM
doug's Avatar
doug
i thought the OP had bumped this thread to say he got better equipment
kyin
Oct 15, 2015 05:54 AM
350z82
Oct 1, 2015 06:25 PM
