need help from audi guru
Old Aug 23, 2006 | 07:13 PM
Gooey's Avatar
Gooey
Default need help from audi guru
tryin to install my dvd player whats ACC+ and 12v constant?? i have 2 power wires and 1 ground?? which ones to i hook up to what??
Old Aug 24, 2006 | 06:19 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
ACC+ is a 12 volt DC source controlled by the ignition key. ACC means accessory. This source of power turns on and off the radio with your key in the ignition so that the thing doesn't drain the battery.
12V constant means a constant source of battery power. That source is going to keep your radio's memory charged and also assist with flipping your fold out screen if you have one.
Old Aug 24, 2006 | 07:41 AM
Gooey's Avatar
Gooey
ahh that makes perfect sense. Thanks for the help sir.
Old Aug 25, 2006 | 08:11 AM
Gooey's Avatar
Gooey
if i dont connect the constant power does the unit not work? cuz my dvd player is not workin right now. I just connected the acc+ line to the wire thats powerin my radio and screen. grounded the black line to the body and i have that 12v constant line not hooked up. Any suggestions??
Old Aug 27, 2006 | 05:41 PM
boostdgli's Avatar
boostdgli
i don't know if you have ever been to either of these, but you could get a detailed answer from vwvortex.com and possibly dubohio.com. vortex is my strongest suggestion though
Old Aug 28, 2006 | 05:29 AM
Gooey's Avatar
Gooey
well i got it working this weekend. dvd player is pretty sweet. Had to connect the constant 12v line to make it work
kyin
Oct 15, 2015 05:54 AM
ares
Nov 21, 2002 06:28 PM
N74DV
Nov 3, 2002 01:10 PM
mattyZ
Jul 25, 2002 06:03 PM
