Replaced Front Speakers and Tweeters
Old Mar 19, 2003 | 03:42 PM
Intrepid's Avatar
Intrepid
I've now replaced both the front and rear speakers. Fronts were 4 ohms and the rears were 3 ohms.
Old Mar 19, 2003 | 05:18 PM
slaponte's Avatar
slaponte
I just replaced mine. Installed the MB Quart RSC216 on the doors, all the rest of the BOSE system intact.
Result :
Good : much more clear audio up front.
Bad : now I can tell even more how underpowered the system is/feels.
I am happy I installed them, but not "overwhelmed" with the results. Of course the sound shop agrees : it all has to go!
Old Mar 19, 2003 | 09:24 PM
jabroney12's Avatar
jabroney12
MBQUARTS are powerhungry, get at least 100rms per side and you'll be set.
Old Mar 20, 2003 | 11:02 AM
maserom's Avatar
maserom
Intrepid, Did you replace the stock wire? I'm planing on doing the exact same thing. \
Old Mar 20, 2003 | 11:20 AM
noahbuddy's Avatar
noahbuddy
I think most people are using the factory wires for the front doors.
The reason is the connection through the car body isn't simply a rubber gromett, it's an actual plug with one side in the car and one side outside of the car.
As suggested you can drill thru the plug or thru the body. Either case was too "much" for me.
And, I found there was plenty of room between the door and the door panel for installing a crossover for the tweeter.
Old Mar 20, 2003 | 03:43 PM
scully32's Avatar
scully32
I am thinking about replacing my front and rear speakers and adding an amp but keeping the stock (non-bose) head unit. My question is, will this sound like crap? I am not considering adding a sub because I don't need it to hit that hard.
I just want something I can jam to fairly loudly down the highway that sounds good.
Old Mar 20, 2003 | 03:58 PM
jabroney12's Avatar
jabroney12
The speakers will sound fine off the factory HU if ur not a audiophile. But your gonna lack the fine tunings that you can benefit from the HU like crossovers, HPF, time correctoin (alpine only), and a better S/N ratio compared to the stock. Add the amp and if you like how it sounds then keep it that way.
Old Mar 22, 2003 | 12:41 PM
SnoopyZ's Avatar
SnoopyZ
Originally posted by Intrepid
The new tweeter is installed in the same location as the stock tweeter.
Did you cut a bigger opening (tweeter location)... I heard some people saying that the stock tweeters opening is actually blocking the sound. I am interested in know whether or not it is...
Old Mar 23, 2003 | 02:40 PM
scully32's Avatar
scully32
Question Is this a good deal?
I think I know the answer already but here is what a local stereo shop in Phoenix quoted me. I asked for a decent sounding system and I did not want to replace the HU or put in a sub.
If this is not a good deal, how would you go about it? I do not have the skills to do an install myself.
JL Audio 300/4 Amp $499.99
MB Quart DSD 216 $329.99
MB Quart RKC 116 $299.99
AMP Wire kit $50.00
oem premium sys interface $80.00
Labor install interface $35.00
Labor amp install w/rack $125.00
Labor comps install $80.00
Labor coax install $40.00
Materials total: $1259.97
Labor total $ 280.00
I've checked and it seems like I could find the amp and speakers on eBay brand new for MUCH less, but then I don't have an idea how to do the install.
Any thoughts would be welcome!
Old Apr 30, 2003 | 08:15 PM
fosterspecial's Avatar
fosterspecial
That sounds like a lot. I know you can get the amp and mb dsd216 much cheaper on the internet. The dsd go for 159 and the jl goes for 379 at onlinecarstereo.com. kustom kar in phoenix sells JL stuff cheaper than that and wont charge for the install on whatever you buy at their store.
Old May 1, 2003 | 07:12 AM
scully32's Avatar
scully32
fosterspecial,
Thanks, I was able to get this set up on eBay for hundreds less. IU even upgraded the speakers and added some Dynomat to the doors and it sounds great.
Pleask
Dec 21, 2021 03:17 PM
kyin
Oct 15, 2015 05:54 AM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
samansharif
Sep 25, 2015 12:31 PM
