sub wiring question
Old Sep 13, 2006 | 12:10 AM
speedlimits's Avatar
speedlimits
Default sub wiring question
i have (1) 12"sub before wired in a 300x2 amp. im not sure what wiring method the installer used
then i just bought a box and 3 10" dvc subs. can i use this new subs directly with my old wiring or do i need to rewire something?
Old Sep 13, 2006 | 12:16 AM
Mike Wazowski's Avatar
Mike Wazowski
You will need to determine how many ohms total you want to produce and wire accordingly.
Here is a nifty little site that has different wiring diagrams for different ohm loads.
http://www.crutchfieldadvisor.com/IS...rs_wiring.html
Old Sep 13, 2006 | 12:19 AM
speedlimits
thanks!
so what "ohms" do u prefer 2 or 4? i only have a 300x2 amp for the subs
Old Sep 13, 2006 | 12:21 AM
speedlimits
another questions, is the "ohms" stuff is just about the sub wiring or u should do something on ur amp wiring too?
Old Sep 13, 2006 | 12:22 AM
Mike Wazowski
your amp is set up to produce power at a certain ohm load. If you amp cannot handle 2 ohms you will fry it.
Look through your amp manual and it will tell you what is recommended.
Old Sep 13, 2006 | 12:24 AM
speedlimits
got it! thanks!
Old Sep 13, 2006 | 05:41 AM
MUZZY's Avatar
MUZZY
make sure your speaker and amps are on the same ohm load capabilities.
for example if you have a 2ohm amp you need 2ohm load or higher subs. try not to hook up 4ohm amp into 2ohm subs
Old Sep 13, 2006 | 09:06 AM
Mike Wazowski
like what post 5 says.
Old Sep 13, 2006 | 03:00 PM
speedlimits
any idea on the specs of the old school PPI sedona series 200IX(100x2)
thats the amp im using for the 3 10" dvc subs
thanks in advance
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
